  • Replies 951
* runs in *
Throws egg back at Sinful
*runs out *
puts out fry pan catchesegg cooks egg and eats it
The real question is:
If we had babies would it be an EVO?
Do two GTR's produce an EVO? Did anyone do genetics / cybornetics at Uni?
I would believe if you look at the genetic make up of two GTR’s the molecular structure and compounds would make it impossible for the fusion to take effect for a EVO to take shape, as the structure and components are such of a high grade in a GTR it would not be possible as the cheaper tackier internals and exterior of a EVO just make the idea of this just silly.
Now if you splice a pot belly pig with an elephant then that would be cool it would be a bellyphant.
That would just be like having a baby with down syndrome
Who ever told you your facts you need to ignore from now on.
The weekend of DECA (Aug 25-26) is a round of the AMRS at Winton. So IF there is any cars there practising they will be pretty cool to watch. But given Winton does their Friday's in 3 groups of 20mins (20mins Bikes, 20 mins Racecars and 20mins street cars) the amount of track time you'll get won't change. But I doubt there will be many there given the Saturday is practise for the AMRS cars anyways.
Plus it's a $100 and its 3hrs from Melbourne so I've never seen more than 10 cars there on a Friday - although this may have a couple more given it is the week before Dutton Vic and few cars could be out for a shakedown / giving co-drivers a test run behind the wheel. But you will leave the day with more than enough laps under your belt to have made it worth while.
blame duncan for my facts...
and blame me for my paranoia about a packed track.
anyway.. given you've cleared that up for me! I'm in for winton
who in VIC is going?
I'm still good for Winton on Friday. If I'm driving that many miles, getting another day of motorsport is a good thing.
Are passenger allowed at Winton? Would be good to catch a ride with one of the locals to learn the track.
I just spoke to Winton and since the round of the AMRS is on that weekend it will be a cars only day with the sessions split up between open wheelers / race cars / street cars. So should be great to watch.
No passengers unfortunately - and you can't even practise on Xbox :domokun:
But here's a half decent youtube link for some visual ideas
excellent TJ!
Jess... I'll get back to you re: accom tonight, or early morning tomorrow sometime as I need to organise what I am going to be doing on Thursday night for accom for Winton (I know someone said something about it but I've gotta find the time to go back and read about it)
excellent TJ!
I think they are staying at shepparton and driving to winton friday morning?? as not far really
Is that right guys??
I got a passenger now!
Or =( im undecided at this stage
HI5!!!
Sif undecided!!! Are you going to do winton?
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
