Is it an all W/End thing then?
How far is it from Sydders?
So I guess am toooo late to have a go then this time.
How far from Syds is it, and whats the cost to get in?
How many going etc?. I kinda thinkin if its about on Sunday, my Line should be ok for then, So I might fly down there(depends on this nasty oil leak on fromt of the block)
Sorry about all the Q's, but cant get access to the tube from work.
  • Replies 951
Read -> http://www.sauvic.com.au/deca
Think all places for the day are filled.
15 Cars last I heard + some spectators
It's on a Saturday 25th Aug. But we stay there Friday 24th and Come back 26th.
It's in shepperton (Country Victoria) It think 6-8hrs drive?
Im new to it too, so I dont really know how or what's going on. :P But im looking forward to it.
Dunno.. Isnt Syd to Melb like 8hrs? and Melb -> Shepperton = 2hrs? Soo.... 6hrs? Im only guessing here. Though I shouldnt ASSuME.
Better be lot's of BeesPee stations on the way.. Might bring a petrol can.
Well according to the BP's triplocator -> Trip : 728.94 kms 8:33 Hours. So I guess it's ~8hrs from Syd -> Shepparton.
I thought Melbourne was 11 hours give or take...? Meh either way... did someone say "ROADTRIP" :P
http://www.bp.com/iframe.do?categoryId=901...ntentId=7024297 <---pretty good site, shows you where you can stop for BeePee stations..
With strippers? :P
With strippers? :thumbsup:
Haha I so need one of these in my car for future reference!
COrinne those tops look great! Count me in for one indeedy!!
I might be heading down Thurs, make more of the time down there.
Sure thing.. Im just trying to generate a bit of interest.. and see how much pricing will be
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
