VIC has excellent contacts and generally gets things at a reasonable rate if that helps.
How many are you ordering?
Just contact BEC, she knows the drill for the SAU-Vic supplier :)
Min order is 20!
I'll talk to Bec see what she says..
  • Replies 951
Ok I've got a costing for the shit's they work out to be about $43 each.. The most expensive part of the cost is the set up fee's for the front side of the shirts..
I'm going to see what I can do to reduce these costs..
Ol mate Benny put the cost of shirts up a bit!
Anyone who is heading down a day earlier (Thursday) know the full details about the Winton track day on the Friday? Ie... cost to get on, pay on the day? need CAM L2S? full circuit or 2km curcuit??
Cant find any info.... will go back to looking now....
1. do you need a cams licence for the track or any
You will need either a CAMS or AASA license yes.
2. how much is this for the day
It's $100
3. is there anywhere you recommend to stay on the thursday night
My advice to the others is just to stay at the place we stay at Shepparton as it is only 30-40mins down the road
4. is it normal long shirt/jumper, pants, ankle to toe shoes and helmet
yep thats fine
got told this hope it helps
that site doesn't really tell us what we're after
anyhow.. i just called them... Friday 24th August is the National Circuit. It'll be $120 and you'll need all the usual stuff (considering you need fire extinguishers etc for deca i didn't ask about this)... Gates open at 8am, racing starts about 10am and goes until 4:30. 30min sessions.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
