  • Replies 951
that's more like it
what's winton like? like wakie or ec?
Id say more like Wakey... dont think as technical as E/C..... open plan except pit straight and just after turn 1-2.. i think Winton turn 2 is where Paul Morris (V8's) had the huge crash flipping his car over and over into the wall last year
Okay then.....
lets try this...
Whoever gets best time for Winton between you and me, loser has to put a sign on their rear windscreen for all Saturday DECA saying
"I have herpes" :laughing-smiley-014:
Fu(king lol!!!!.. hahahaha!! good call Ando!!..
Try not to include Steve-o in that bet as he has already contracted every STD under the sun from all the bum sex up on Oxford St.. he would wear that sign loud and proud!! :D
TJ,
I actually have a "drift button" on my hand brake.
So I can rip the H brake up without holding the button, and drop the h/b when Im finishing the turn/slide
and to use the h/b to park, you pull h/b up and flick out the button
Anyone know a cheap and easy way to make sure your H-brake stays button in? Had it lock on one run last year which was not a good thing. Duct Tape?
I removed my handbreak boot and drilled a small hole through the base of the handbreak while depressing the button. The hole was right next to the ratchet release and I just put a little 2mm thick bold through it.
Pull it off - have a look and this will make sense. A small bolt can hold the handbreak in.
TJ,
Don't you have enough power??? Sif need hand brake.... compression lockup in, fully sick foot to the floor power out......... :D:P
TJ,
i've seen it...rather nifty little gadget....
TJ,
Easy to install? I have a drift button sitting at home and have NFI how to install it!!! Wanna do it for me dude!!?? :)
I'll even provide beer!! :thumbsup:
Sam has been in it with me using it :thumbsup:
hahaha
Ando dude! I actually got Nath to fit it at Grey imports man! Anna and I tried one day but it had aids...sorry dude :(
Bring it with you and we'll see what we can all do :) haha
Anna, theres some tight turns on the skid pan courses that to get a quick time, hand brake is needed!
Slider!! that would be tops!!
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
