  • Replies 951
I have the week before off so Winton is an option. Would rather not drive down alone so assuming I can get at least a passenger I think I'd like to get down a day early and learn the track secrets of the Vic boys. If they get me running faster maybe I'll defect to Team Wang
I know this is still some time off but I vote for a very, very early morning start. If some of the guy/gals from north need a place to crash the night before, we have space.
i'm considering going down early aswell for the track day, have to confirm a couple fo things, but 75% sure atm, i'd be up for meeting up and going down.
LOL. I'm just hangin' around seeing what crap you fools are talking up. *Runs and hides before flaming starts.
Right you are getting two boxes of tissues :laughing-smiley-014: looking forward to going into battle
well I know I will lose but atleast ill have fun doing it.
This is a fantastic effort for NSW people and please tell people that we are more then happy to get spectators down too it is a fantast weekend
everyone go to the toilet before we leave :/
Chris taught me a good trick.. go once when you need to go.. then when your just about to leave go again. :thumbsup:
Wooo playing with the new blackberry :(
Where did you guys meet up at last time?
we met in a carpark 2mins from the intersection with king georges road (which you would come down to get there) and the M5 in beverly hills.
i assume its going to be the same place again??? will we fit there???
:/ Hmmmm Jess.... Andrew.... can I sleep on your beanbags on the Thursday night before puhlease! Otherwise it will be a 5am wakeup call for the 8am meetup!
they have a spare queen size bed you know...
but apparently thats mine :(
cause im too lazy to get up the extra 10 minutes earlier :thumbsup:
So it sounds like a few of us (Steveo/Sam/me) might make it down to Winton for a track day on Friday. I'm up for a very early departure (5AM?) to beat traffic. Like to get there and chill for a bit.
Scotsman - it there a place to crash near Winton on Thursday night or should we book into the cabins a night early?
For those of you who are new - this F'N rocks. It don't get much funner. Of course we will have to start dominating the Mexicans...
NSW TFW
I'm interested in this morbit fascination you seem to have with tissues...
Tell you what! SAUVIC will organise a tour of the Kleenex factory in Shep for ya.
    • Yep that makes sense, thanks! I guess flogging these turbos in winter is more preferrable lol.
    • Bahahaha, bloody hell Greg. You've got bent and broken things, but instead, you're replacing perfectly good items. This story keeps getting more gregged!   Also, I'd 100% replace that reo if I were in your shoes, unless you panel beater is REALLY good. Even if you put another GTT one on there. Just because you've done so much nice body work lately, I'd say repair the body work fully  If it were more drift car spec, I'd be all "Hit it with a hammer and send it!"
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
