  • Replies 951
What the???
I dont like the idea of you driving by yourself :P would prefer we stick together
Brad and I are heading down a couple of days early because I want to go to Melb because I have never been there before. So we are going to do winton as well.
chicken pie, the 2nd best type of pie there is :D thanks sweetie :P
PS: you will be bored in like, 2 hours... I have been there before, i never want to go again... not without a horde of sydney siders to accompany me :mellow:
Hehe mmm.. pie.. I'm hungry!
Shhh don't say that.. I want to go down there.. just to say I have been to Melbourne and it was ghay.
I'm really going for the shopping..
I am accompanying myself so I will never get bored!
Corinne that is a great idea...Its cool to see other cities
Wish I could go earlier so I could go visit my best mate :P
Maybe I will do it in November
Yep, Melbourne has always been on my list, I just haven't gotten round to it yet.
Couple more states to go for me. WA & TAS
You should definitely go!
No CB whoring with me then? :mellow:
I will be a giant CB so you can sit at home and I can still talk to you. :D
Yea - atessa controler in this weekend. Maybe a clutch before deca or just lower RPM launches. Can't wait to go back and run with the Mexicans.
So what kind of creative names do you suppose they will come up with for the events this time?
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
