hey guys its a funny idea i know but i want a car suitable for drift and curcuit work in one so im lookin at a 32 gtr and for drift i will be using a rb25 gearbox and gtr sump with the front diff chopped off to save weight and stop the front end being soo heavy. now i want to get rid of the front driveshafts (axles) going to the brake hubs. how do i go about this? do i need to replace the suspension arms etc with 2wd ones or can the shafts be removed on the gtr ones and its fine to bolt rims on and go drifting?
please dont tell me to buy a 2wd as i want the option of both, and i know sump off is an engine out job but thats simple ive done it plenty of times in the past :)
any info welcome
thanks
https://www.sau.com.au/forums/topic/174350-making-a-gtr-2wd-for-good/
I have just made my GTR full time rwd to test a motor I am building, as I didnt want to change the tailshaft and leave the gtr box I did it all so I can change it all back.
You need the front driveshaft to hold the hub bearings in, so I simply put my front shafts in the lathe and parted them off at the abs sensor and bolted them back into the hub.
I then cut the diff off a gtr sump to make it rear wheel drive only and it still works as per factory.
I also cut the transfere case off a GTR and took all the 4wd stuff out then re welded up the whole.
Hey Daniel thats exactly the info i needed mate, thanks for your input :/
2630GTS i want the car for circuit work as well so i would rather 4wd option for that purpose as the rb26 i have currently in my current ride has 605rwhp and thats what im going to install in the gtr. gtr's also have ally bonnet etc and better brakes which makes it ideal, and i need a 26 spare engine to put into my current ride to replace this one so all in all its easier and cheaper with a better outcome :thumbsup:
cheers again guys
