  • 1 year later...
Sorry to bump an old thread, but..
Has anyone got any reports on these pads since they have been around a while now?
I'm about to replace my front rotors/pads, and the brake shop im using is trying to push me towards the bendix "race" pads. Currently i'm using DBA rotors with EBC red stuff pads as a street/track pad, and have been pretty happy with their performance, so deciding wether to get the reds again or try these out. Any opinions?
I have just gone from Endless SSS to RaceBrakes RB74 and i won't be going back, have used EBC greens and the bendix range before... They are good value, and stop well cold, and work better the hotter they get!
also, support a Melbourne business :D
Yeah i have heard good things about the racebrakes pads.
I guess my main concern with trying the Bendix "race" pads is that they have been around a couple of years now and there is practically no information/reviews on them on the web, plus i have used Bendix ultimate's before and they were possibly one of the worst pads i have ever used.
Thanks for the input.
Scott.
Hmm....I have RB74 all round currently with DBA 4000 series rotors on front. Done 2 track days only and 55,000km road. They have about 5000km left. Front rotors look like they might need to be replaced (replaced when put in the RB74) and rear rotors also (didn't replace last time).
I was thinking of going to ultimates since I used them on the 200sx previously but never gave that a flogging since it handled like poo. So really I don't know how good ultimates are. If they aren't better than RB74 and also eat rotors like RB74 do then I might have to rethink.
Only thing with RB74 is they tend to squeel a lot, so you'll need to use copper grease on the backing plates.
Edited by simpletool
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
