Well sorry about the title.
What I am after is the PCD, spacing, & offset from the rotor centreline(in plan view) for the two bolts that hold the stock caliper onto the hub, or in the case of an aftermarket caliper hold the mounting bracket to the hub.
The two are shown in this photo (Pinched from this very forum) just in front of the drive shaft.
TECHNICAL SPECIFICATION
Piston Size: 40 (x2) mm. Piston Size: 44 (x2) mm. Piston Size
Piston Area: 55.54 sqr. cm. Pad Area (Annulus): 62 (x2) sqr. cm. Pad Thickness: 18 mm. Disc Diameter: 355 mm. Disc Thickness: 32 mm. Hydraulic Threads: M10x1 Mounting Hole Centers: 130 mm. Mounting Offset: 55 mm.
aka f50 or "granturismo" caliper
or the "f40" caliper:
except 38/44mm pistons
both using this pad:
as far as the bracket goes it all depends what dics/had combo your using
Thanks for the info.
What I was chasing were the locations of the bolts on the other end, ie as they bolt up to the hub. The outside biut is ok as most manufacturers publish this data, but the Nissan end of it I don't have any info on & don't believe I can measure it up accurately enough.
well its 100mm spacing. and ofstet is usualy centerd around using a rotor with a 15mm hat height. most calipers that are radial mount have around a 50 mm ofset. its really a case of having your disc and caliper sitting on the disc with new pads and getting out the ruler
Hooray, I'm helping! (that's my photo). I have nothing useful to say I think, but I think it's funny because I was just browsing around and had to do a double take at the photo! Oh and I wanted to say thanks to T04GTR because your data helps with the project I'm currently doing. Namely, buying and fitting replacement discs and pads for my non-standard setup, which shouldn't be a project but it is!
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
