dont they have them on carmate.com.au? maybe send them an email an ask.
might be worth sending vivagarage.com.au an email about it too?
or theres a trader on here called slidewise that can get all sorts of stuff through yahoo auctions, definatley worth dropping them a lineCLICK THIS LINK
Custom Carbon
81 Basalt St Geebung
QLD 4034
Phone: 07 3865 2014
Fax: 07 3865 2436
www.customcarbon.com.au
not sure if they still in business or not as site didnt appear to work when i just tried it.
haven't used them or seen their work ... good luck.
www.carmate.com
By the way, you do know that carbon bonnets are illegal right - as if you have an accident and your engine bay is up in flames - your bonnet will melt within minutes and your whole car might then go up in flames.
www.carmate.com
he wanted carbon bootlid not carbon bonnet.. and dont think carmate sells them
Oopps - my bad, sorry!
Try www.xxxbodykits.com.au ask for Omar tell him Kevin with the Black R33 Skyline referred you - I believe they have some, he'll look after you... they're based in MELB so if you're interstate, I'm sure they'll happily courier it to your expense.
Regards,
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
