  • Replies 49
If its the same as anything (S1 I am assuming?) then it will be the same as R33 GTS-4. In my experience the GTR's have everything just a little chunkier. (front driveshafts for example)
Do us all a favour, and if you do get the Nissan one, can you ask the counter monkey to compare the part number to the GTR and GTS-4 and let us know the results?
Cheers
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3201027
If the boot has split, and the grease is all over the inside of the wheel, what sort of life expectancy do you give the CV? I would replace it, myself, just to be on the safe side. Have you ever seen the damage a CV does when it lets go?
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3201158
For your info, the stagea outer boot kit part number is 39241-50A92, and FAST shows it as being the same
for the 260RS, GTS4 and GTR.
You rock! :mrt:
I don't suppose you got the same info for the CV themselves?
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3201460
Thanks dude :P See you now an again cruzn round the terrace newy,nice stagea man :mrt:
Cheers mate, that's what we're here for :) . Be good to meet up some time, you should cruze down to the SnS with the rest of us.
I'll have a look at the CV comparison later tonight, and see what the go is.
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3202690
Just take it to any reputable CV speciallist around you and get them to do it for you :P
nice and easy.. less down time than doing it yourself
and depending on what the condition of the CV joint is when you take it apart .. it may or may not need servicing. Dont stress its all too easy! just a few hours waiting around for them to do it
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3202698
Just take it to any reputable CV speciallist around you and get them to do it for you :thumbsup:
I second that. I had the same problem on mine - right cv boot. Took it to a CV joint specialist and had the boot replaced for $80. Apparently no problems with the cv joint itself. :dry: Hopefully yours is the same.
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3205006
  • 3 weeks later...
Has anyone actucally had their CV Joints replaced yet. (I'm particularly interested in hearing from Brisbane peoples). My boots are split and grease on the inside of the wheel. Now not ever having anything to do with CV's before (damn AWD FWD cars :) ) what are the costs like. And is it a job for any normal mechanic or is it better to see a CV workshop (see plenty of them in the yellow pages). My girlfriends pulsar is also in dire need of CV's too (because I just got the boots replaced on hers and the joints didn't last too much longer before the knocking started) so I just might as well kill all the birds with one stone.
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3230970
if you can find a good ( reputable ) place then your FAR FAR better off just taking the cars to them and letting them do it. I have attempted to do the outer boot on a pulsar CV joint and it was a royal ass pain . these guys at the CV shops have
A) all the tools etc needed to do the job correctly
b) spare parts etc
c) the know how of what to do etc.
I know Dale ( stinky rooster ) has an abject fear of letting others do his mechanical work .. but I would dare say even he might agree with me on this matter.
CV joint place all the way
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3233285
I don't think you guys read the post properly. I wasn't asking if it was an easy job for me to do but wether it would be better to take it to any normal mechanic or to take it to a specialised CV / Driveline workshop. Be fu**ed if I'm going to do something like this myself. And my cars rearley see a workshop either unless its something I really don't want to do.....this is one of those things. I really just wanted to know what costs are like.
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3235283
Sorry for getting Off topic
Yeah I would take it to a C.V place. Because if you took it to your local mechanic he would probably just order in the parts from a CV place. My logic is that fixing CV joints is their ( the CV people ) bread and butter , so you would guess they would know them better than a standard mechanic.
https://www.sau.com.au/forums/topic/174430-split-cv-boots/#findComment-3235296
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
    • Brand was ard.   I also threw a brand new battery at it and beefed up the wire from the alternator to battery and added an extra earthing point from the battery
    • Evening all,       I'm replacing some bolts on my RB25 with probolt Australia bolts.       Does anyone know the following, m5 m6 etc 10mm 20mm etc       Coil cover   Cam covers   Plazamaman fuel rail   Front cover (timing cover)   Etc   Any help would be awesome   Or any lists anywhere
