Hey All..
I'll fill you in on what the bad part of my story is... 2 weeks ago I met up with R31Nismoid up in Sunshine for a cruise, and after a bit of 'harder-than-average' driving, one of my pistons failed causing my car to turn into smoke blowing, un-driveable piece of japanese metal...
But After getting it towed home, to SEAFORD... and then to the mechanic I learnt the terrific news Yesterday that the 3 yr warranty I bought when I got the car, is going to pay for the full cost of a rebuild.. Mmm.. Rebuilt RB25.. :D
BUT, The reason for my post is mainly a question.. Anyone out there had their motor (RB25DET) rebuilt? And what was it like afterwards? Like what can I look forward to? Besides an engine that should run smoother than factory...
Anyone got some comments on What I can look forward to?
Cheers ;)
Guest INASNT
where did u buy the car from that is giving u a 3 year warranty?
since they r paying chuck in some forged piston, gead the head fully ported and polished, chuck in some jun/hks cams, cam gears, titanium valve springs, heavy duty valve springs, bigger oil pump.
:D
Well INASNT I got the car from Success Motor Imports in Garden Vale (You'd know the owners Stagea, it's been in HPI several times) ....and the warranty isn't tru them, it's a company they buy the warranty's from...
and as for all the nice performance parts ... they are paying for a standard rebuild.. not a high performance one.. unfortunatly :D
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
