When going from 3rd to 4th if i try slam it in it crunches. But if i ease it in gently its ok and doesnt crunch.
If it is the synchro, am i doing damage to the gear when it crunches?
Im gonna be looking at putting some Redline Shockproof in as it seems every thread recommends it, but i would also like to know how much it would it roughly cost to get someone to fix ALL synchro's if its needed?
All advice appreciated. :(
Edited by GTR_STEALTH
https://www.sau.com.au/forums/topic/174507-does-this-sound-like-a-synchro-prob/
I purchase my R32 GTS with gearbox issues. I had it checked out and the specialist advised the main bearing was pretty much farked and the 2nd and 5th gear synchro's needed replacing. It cost me approx $780 with 1yr/20Km warranty. IMO i dont think it will be cheap.
good luck :(
Why do u need to slam it? Its a nice way to kill a box as u are finding out.
It is syncros, and usually when they are replaced they only do the ones that require it.
I had a quote from nissan a while ago, and all syncros + parts was about $550. Might have gone up since, or u might not be able to get all parts.
Had same issue, plus 2nd > 3rd shift crunch if moved too quick (not fast enough to be branded abuse)
Redline shockproof cured all, plus allowed me to actually get it into 1st when cold and rolling at walking pace.
Have heard on NS i think, that Redline can harm the box. I don't believe this though.
M
Give these guys a call;
http://japanesegearbox.com.au/
They quoted me $990 swapover for a fully rebuilt gearbox r32 gtst
and $150 to remove/refit new box
edit;
Redline doesnt fix things, it just makes the noises go away. You're still causing damage to the box just your extending its life with a temp fix with redline.
I had redline put in 15,000km ago and the problems have re-emerged.
Cheers
Have you changed the oil since you bought the car?
I had exactly the same symptoms, weak syncho's into 4th with a quicker shift at higher revs. Changed oil to vmx80 and nulon g70 treatment. Now it is very nice to use.
I was advised against the redline lightweight shockproof as the chemical rating(?) of the oil eats away at the material the synchro is made of.. heard this from a number of sources.
james.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
