ok guys after getting my car back from the panel beaters getting the back rear replaced, and putting in my new spark plugs ( NGK iridium MAX ) i notice my car is losing boost when holding on 5psi or more ( like it doesnt wanna boost )? and like this morning i go to boost my car, its seems like it cuts the boost ( after 4500rpm ) with no power and then boost kicks back after?
could it be coils or coil? intercooler pipes loose? etc
cheers
https://www.sau.com.au/forums/topic/174509-~losing-power~/
checked for leaks but no sign? *NOTE* can my bov ( hks ssqv ) cause these problems coz ive noticed afew times today that i instead of the whistle it made a wooosh? i was told that bov symptoms can also stuff up your timing? which i think could cause the problem im having now? but im up for any ideas :(
cheers
https://www.sau.com.au/forums/topic/174509-~losing-power~/#findComment-3201977
Does it take a long time to rev out?
Kinda gets stuck and feels like the cars not going any quicker?
When it boosts, does it hit full boost, then drop back down a few psi?
Does it hesitate and backfire?
yep things that happen are its like car wont go any faster coz of the lag and also when hitting full boost it hesitates then back to normal for a couple of seconds and then backfires? also this problem accured when i got my new spark plugs installed? NGK IRIDIUM MAX?
cheers
https://www.sau.com.au/forums/topic/174509-~losing-power~/#findComment-3203543
cheers
What I described was symptoms of a boost leak. Usually when intercooler pipes were not done up properly. Also the woosh sound instead of the regular bov noise can also be caused by a boost leak.
How did you test for leaks?
You can do a leak test.
What you'll have to do is,
1. take your pod/airbox and AFM off.
2. use a baked bean can (full) and put it into your rubber intake pipe (assuming its still the stock one).
3. tighten up the hose clamp onto the tin creating a seal.
4. Open the throttle body with a brick on the accelerator pedal, so you can read pressure on the boost gauge.
5. take a hose that is plumbed into your intake between the turbo and the plenum or off the plenum itself.
6. Get an air compressor and pressurize the system through the hose and get someone to read the psi on the boost gauge. you only need about 5psi. you can use the compressors at the servos.
7. Listen for a leak. and use soapy water in the spray bottle to find exactly where it is.
It is easier to find a boost or pressure leak using this method because the car is not running.
If it's not that it may just be your plugs. But usually plugs just cause a hesitation/missfire.
https://www.sau.com.au/forums/topic/174509-~losing-power~/#findComment-3203587
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
