I remember ringing one of the guys in the yellow pages a few years ago. basically got a lecture as the guy seemed on his high horse for no reason and mentioned a few times that he polishes the "Rundle mall balls" and can do a show room polish that will clean with just petrol blah blah. I try stay away from knobbers like that...
If u have some time and patience u can do it yourself depending on what it its. U just need to use some wet/dry emery paper to take it gradually down to a fine polish, then if u can use a bench grinder setup with a polishing wheel, and use clay will make it a mirror.
Really depends on what u want done though (is it smooth and flat, or has lots of surfaces etc) and how well u want it polished or mirror....
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3202188
Got most of my engine bay stuff polished through [boostworx] Shaun's guy. Also, currently getting some stuff chrome plated by Windsor Electroplaters in Windsor Gardens who also do polishing & are a bit pricey but, they were the closest.
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3202231
If you are will to put in some elbow grease andz you can use metalsol
i think it is called or something similar to bring the shine back to your exhaust tip.
That would be Autosol, Works a treat too!!
I need to get my whole car deatailed and cut n polished, just want a pro to do it tho......
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3202716
ahhh thanksssss, need the shiny exhaust tip for the rice factor
autobarn would stock them i guess
Hey Andy, try Meguiars NXT generation Metal Polysh. Bit expensive, but the lady at eliz autobarn lent me the store sample of theirs and its the best one i have ever used! Was good for the radiator panel, intercooler pipes and the exhaust tip!
As for the polishing Shaun, the best advice would be to try to do it yourself. What are you polishing?
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3202957
I'll get you a number for Stan the polishing man, get stuff done through him at work. Just file out any major marks that you don't want, ie. casting marks and he will bring it up beautifully and for next to nothing.............
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3203187
I am polishing my intercooler and pipes now that everyone will be able to see them with the new bar in place and there will be lots of other stuff as i go along and bring the engine bay up to scratch.
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3203701
i use ultra gloss for body polishing i like comes up soooo shiny especially after using the paint cleaner as well that you can get in a dual pack...........
ohhhhhhhh metal polish...i read it wrong!! i got meguirers metal polish very good
https://www.sau.com.au/forums/topic/174537-polishing/#findComment-3206555
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
