Neo Gear Oil
I think it's the same. It all comes from the same shithole refinieries in SE Asia.
I was referring to the final octane level achieved once 10% ratio of ethanol is added. -
How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
