hi, guys iv got a r33 (rb25t) with 221kw at wheels... sounds good but thats MAX! on 10PSI its only got like 97kw at wheels. iv got FMIC, bigger turbo, 550cc injectors, walbro fuel pump, dump pipe into 3inch stainless, HKS pod, microtech LT-8 ecu...
was thinkin of getting splitfire coil packs but told there a waste??? dunno about that
what mods can i do to make more grunt... budget minded at the mo hehe
thanks guys
https://www.sau.com.au/forums/topic/174610-need-more-grunt-whats-a-good-mod/
  • Replies 49
Posted Images
lol im amusing you ment on 10psi its making 197kw at the wheels. Next mod on your list id be looking at a bigger turbo again. You have all the supporting modifications to support a safe 250rkw. So if your maxing the set up at 221kw im assuming the turbo is the restriction?.
No point in getting splitfires unless your packs are breaking down.
mate youve done all the mods you can do before you change the internals. Im thinking if you want more grunt, considering you have a bigger turbo, crank up the boost. What turbo do you have, so that someone can tell you what level of boost is efficient. Say, if youve got a big turbo such as a gt 3040, you would need to run higher than 10 psi to get good power. but then to get even more power, youd need to change internals to support the stress on your motor :yes:
gee's.....
I agree with 700hp GTR33......
and just to confirm...it is an Rb25 R33 ?
what turbo again?
and those "bolt on" mods?
you get those twopower levels...
97 and 221
Your Turbo and tune seem to me as being at fault
Who tuned it...and what Turbo is it?
i havent dynoed it myself the previous owner dynoed it at JEM, dunno what turbo it is... i had someone who knows there turbos and couldnt tell me... it aint stamped on turbo... its not much bigger than stock
yes, Nice avatar :yes:
mate, something is wrong with your car or someone is telling you fibs - take it somewhere else and get a dyno run....
Sure, dyno's are used as a tuning tool, but your two power levels and boost - its just not making any sence.
Even RB30 non turbos make that power - 97rwkw !!!!! (Well, I know of one that made 101rwkw)
yes, Nice avatar :O
that sounds like what i will have to do... i feel like iv been shafted now... :yes:
if it is bigger, how come it only seems to flow 97kw of air at 10 psi, whereas a stock one can give 180+ quite easily. either your turbo is not suited to the low boost, or you need to get the microtech tuned properly. sounds like you would be better off with a stock ecu atm if the turbo IS bigger
If you want more grunt as in the sound - then get a proper CAI with a bigger POD - pipe it straight to the front bumber and you will get better sound.
Regards,
its a HKS 3 inch neck (luv the mad induction noise :yes: ) with custom heat sheild... but getting straight to bumper will be good... will it make alot of difference in power?... any gain is good for me.
dunno... could it be the turbo is shot or something??? maybe i need a full retune or something...
you most likely dont need a rebuild. get your car on a dyno at a dyno day or something for $50 instead of guessing from what previous owners have told you, and get a print out of the air/fuel ratios and power curve obviously. compare your curves with some from the rb25 dyno thread and go from there. you may find there isnt much wrong after all, or you may find that the turbo or management is totally wrong and u really are low on power. a retune will sort u out, the microtech is a good thing. changing turbos is a bit harder/
i dont think you have any damage, just a system mismatch
no worries i will definatly have to get it on the dyno by the sounds of things, will an air/fuel ratio gauge help me...
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
