  • Replies 49
Posted Images
Extremely wrong.
+1
There is no turbo available, that is only slightly bigger than stock as you say (say a 400-450HP turbo) that is ment to be pushed any where near 35psi.
How do you know it is pushing 35psi? Boost gauge or someone just told you this?
its a HKS 3 inch neck (luv the mad induction noise :) ) with custom heat sheild... but getting straight to bumper will be good... will it make alot of difference in power?... any gain is good for me.
Don't do that...next large puddle you will hit will be your last for the motor....keep it high and out of the rain.
Oh...I know why I liked it and choose it...MY avatar that is...could stare at it for hours....lol
i dont know what sb8 is, but i want 10.
i was thinking that to have a stockish turbo power figure on 35 psi, and nothing at 10 psi, he has a tiny tiny turbo that he is spinning the crap out of to get the air flow. i think there would be too much heat for it to make any reliable power if that was true, so it must be tuned to run a bit cooler.
HOWEVER- ive decided that this isnt feasible (?) now. what he has is a full throttle tune. when he is at lower load points eg. 10psi on the 35psi tune its just not fuelled or timed correctly, and is running crap.
still think that it needs to be checked on a dyno. what if there is nothing wrong after all? does it feel quickish on the road or feel like a pintara
i ran my pod in the front bumper for years in brisbane (when we had rain)
with no dramas
only moved the pod back to the engine bay, coz i got sick of replacing them coz they were so dirty
+1
dyno sheet from when it was dyno tuned at JEM... i can post it up if you want to c it yourself
suppose it makes sence to keep it in a dryer place...
it feels good, quickish like it should running 10 i guess... but on idle it tends to pop and crackle (probably exhaust)... oh and it feels like it has a bit of a flat spot at low revs... i think i need a tune by the sounds of things.
Edited by 4drftn
with no dramas
oh ok, did it perform better in front? did it make a louder induction sound in front?
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
