id like both brake and clutch lines, if you cant get brake im in for the clutch
pm me the details if your taking payments
thanks
edit: its for an r33 gtst if that makes any difference
Edited by tek_01
  • Replies 97
thanks
all together now!
want brake lines more but will go both if you can organise it :blink:
Yes ready to fit. Heat sleeve is to protect it. Not sure if it's needed but it sure wont hurt. UK, hmm I will look into that. Yes it's turning into both clutch and brake. I've been so bloody busy lately sorry everyone.
I'm in for both brake and clutch lines for R32 GTR - Let me know the final price when you know.
Cheers
Michele
Edited by LadyBytes
Ok got the brake lines details:
Goodridge lines ADR approved, anti wip and no rubber like other brands on joins which perrish with heat. Bolts straight on, made in England and quality product. Exact same as V8 Supercars use.
5 or more sets $195 each set of 4 instead of $260 Freight and handling anywhere in Australia $15
I'll now update the first post and get this thing happening.
    • Is it a dog or synchro box? I guess either way, if it is new and crunching in one gear only, it has to come out and go back to the shop to check/measure as there is either an assembly or manufacturing issue
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
