SHIT!! :) I bought a set of rims from ian diffens when i first got my skyline bout a month ago and they put wheel spacers in the fronts to clear the brake calipers. i didn't know they were illegal can i do anything to fix the problem eg take them back and get a set that fit properly. is there a law where they would have to rectify the problem. any help would be great.
If the wheel dont fit, dont use it!
Go back to ian diffen, give them back the rims which obviously dont suit your car, get your money back and go to a dealer who can sell you the correct wheel for the car.
they put ally plates between the hub and the rim. probably a dumb question but whats the difference between wheel spacers and hub locaters??
th hub locaters help fill th gap between th hub hole in th middle of th rim an th bit of th hub that pokes out from th center of th disc rotor
its to stop movement of th wheels on th hubs
are your hubs bigger on the back??? if they needed spacers to clear the brakes then they're not hub locators/rings locators are for when your center is drilled out wider than the hub . hub takes the load studs are just to keep the wheel there and apply centrivical ( ?? ) force .. any one gunna correct me ??
Edited by stilgar
    • Hi everyone, just looking to see what's available in the GTR seat options, testing the waters on what's available. Wanting a driver's seat to replace my old school OG jap race seat, going to re-register the car so need a factory seat. Prices currently seem to go from $300 to $2k for a driver's seat. What's options are there, that's good condition and actually a realistic price? Located Brisbane. Thanks
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
