  • 3 weeks later...
"THEORY OF MAGNETIC POWER
POWER NEO uses a strong magnetic field from the neodymum magnets to re-arrange the gasoline molecules to be in a more structured which provides a more complete combustion. This improves the combustion efficiency, and in turn reduces the amount of unburnt gasoline and corbon monoxide in the hydrocarbon infested exhaust gas. Carbon monoxide is the main component in exhaust gas pollution. POWER NEO is able to contribute to the global warming reduction which is the biggest environmental problem today.
With POWER NEO, the driver will see a dramatic improvement in torque at low RPM levels. This improved torque is a result of a more explosive combustion due to a more complete fuel burn (as close as 100%). Power is improved through out the RPM range without pressing the accelerator too much. This will also improve mileage as a result of lesser fuel consumption."
http://shorterlink.com/?LJ0R0S
I had something similar in my previous car, called a Triple Charger. I was under the impression that it helped with my exhaust emissions after testing it a few months after installing but now I'm starting to think it was the better grade of oil I swapped to at the same time. It was also meant to improve power and economy.
I put it on my Skyline a couple of months ago and monitored the economy. About the only difference I noticed was that it was now harder to start, because it was mounted vertically and the fuel would drain back down the line. The fuel pump has a preset timer on it to fill the fuel filter and prime the injectors when you switch the ignition on, but with this extra reservoir installed it obviously hadn't primed the injectors yet and thus more cranking was needed.
It was hard to say if my fuel economy improved or not, because I installed it around the same time I did some mods to my car. But a couple of weeks ago I got sick of the hard starting and so took it off without doing any other mods. Voila, my fuel economy went from about 14.5L/100km to 13.8L/100km.
So I would say it and all things like it are a crock of shit :)
"Then there was the item that by late 1986 was creating considerable conflict between GM-H and the HDT, namely the 'energy polariser'.
... The HDT press release described the 'polariser' briefly as "a new development, which improves overall vehicle efficiency, ride comfort and stability." Among the claims made by Peter Brock for his invention were that it enabled a car tuned for super petrol to run ULP with no ill effects whatsoever. Such a claim is in defiance of all normal logic, but Brock insisted on the truth of it. He admitted that this was "way out thinking" but it was clear that his faith was beyond question or challenge. On the other hand, GM-H dismissed it in these terms; "as far as the energy polariser is concerned GM-H can see no technical merit in it and cannot endorse its use". Peter Brock's clash with GM-H peaked in February '87, with the announcement that the long-standing relationship with HDT and GM-H was over. "
And then from www.skeptics.com.au
"In 1982, Australian Skeptics instituted an award to be presented annually at the National Convention to individuals or organisations who made the most outrageous claim of a paranormal or pseudoscientific nature in the preceding year. ...
The next award went to an Australian sporting icon. In 1986, Peter Brock, Australia's premier touring car driver, became involved in promoting an "energy polariser" which, he alleged, when attached to the firewall of a car, improved its performance in all fields. The device was not connected to any of the vehicle systems and supposedly worked by application of mysterious "energies unknown to science". Along with motoring journals, the Skeptics conducted an investigation of the device and found that there was no basis to the claims made. The fallout from this affair saw Brock severing his relationship with General Motors, his long time sponsors and with a number of his colleagues. The publicity associated with the case saw the device withdrawn from sale."
It sounds like the fuel didn't even run through this device at all.
The polariser sat on the Commodore's dash/firewall on the inside! It wasn't a fuel catalyser at all, it was meant to affect the whole car via some mysterious energies. It was also meant to improve handling and braking.
What I want a lot more than the polariser are the drugs that Brockie was on when he thought the polariser actually did something :)
I do work with chemistry every day at uni. I dont see how you can "align" fuel molecules. Fuel is a bunch of saturated and unsaturated hyrdocarbons. They are not polar whatsoever. So to to align them using some magnet is just a joke. Try sellin this to any seasoned chemist... However the other ones that release stuff into the fuel like Tin may do somethin, but aligning fuel molecules.. haha.. I should keep quiet now :P
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
