hey guys how are we all,
last week i blown the stock rb20 turbo in my R32 down heathcote raceway
luckily enough i was able to drive the car home 2 hours away
finally got round to replacing it with another stock turbo myself today
took the car for a test drive and seems normal at first
when I accelerate above 3000rpm it pings
slowed the car down and the car begins to hesitate and shake
idles below normal and feels as if it about to shut off.. only for about 10 seconds
then its normal again...
what may the problem be, a cylinder, coilpacks, spark plugs?
this would be greatly appreciated as I did like try fix it myself before taking it to the mechanics
i know i should do a compression test, but I will see what happens cheers
thank you, david
Edited by kelumzi
thank you, david
Hi
Sounds like a boost leak. Check all your intercooler piping, most likely something has popped off, or you havent tightend it up properly again.
Overfuels as you come onto boost @ 3000rpm as there is no boost coming through into the intake plenum/engine, when the AFM is reading boost, therefor overfueling and surging etc.. I think! :P
Has happened to me in 1 of my car's, and was the same story in my cousin's R33 not long ago.
Give that a shot and see how you go, couldnt be anything major.
Hope that helps some how.
Thanks,
Abu
Edited by abu
hey there i have a r33 and ive had the same problem it took me ages
to figure out what was wrong but it was only the bleed valveu ..
i replaced it and it drove smoothly not like choking anymore...
Edited by r33me
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
    • Put a piece of tape on it.   If it's that gone, you would be seeing it on the balancer. It would look rooted. Not in this universe.
    • If you’re in Australia and need a one piece tail shaft give propeller shaft repairs in concord a call. They do all the big Sydney cars and they don’t vibrate at all don’t get one either cv joints, they bind and cause the vibrations
    • Want to change and monitor if it robs again   could be my harmonic balancer is gone   do you reckon it can be bent crank , don’t believe so at 600+ hp that would shop very quickly so can think either harmonic on way out or at somepoint in car life it wasn’t tightened so balancer wobbled
