HAHA point, car is not imac, most people are looking for a big hp gtr that is imaculate.
There are a few niggling little problems that I am unable to repair on the car before I sell it as I am very short of money.
Other than the paint, what things?
  • Replies 76
Posted Images
Dash vents, front cv boots not the cv's just the boots, speedo cable, front brake pads are getting low.
Thank you to everyone that has shown interest and offered swaps, although due to not being able to come to any agreements I will be forced to keep the car. It will remain for sale for the time being as I start to fix all the little problems.
The exhaust has just been repaired at castle Hill exhaust. A 3inch high flow stainless cat was installed and the wastegate was plumbed into the exhaust before the cat to make it nice and legal and much much quieter.
would you be interested in swapping with a white 97 rexy. basic mods ie pod exhaust intercooler struts bar sway bars sti wing bov and more. roughly 3 grand cash your way. rebuilt engine 30000kms ago with receipts. if so let me know and ill send you more info and pics.
thanks jason
thanks jason
Sounds good, send me some pics.
By the way to anyone who is interested I can get a pink slip no probs for the car as it is legal.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
