RockGTR has moved to Queensland for work so after we rebuilt his 32GTR we sent it over to him a few weeks ago.
Yesterday in Queensland it was the fastest car at the strip. 10.4 1/4, OK 10s not special these days but the specs on this one are a bit unusual for 10s.
Nexen radials,All inturnals are stock but with Arias pistons and N1 pump,stock gearbox, GT35 Turbo on china manifold still using AFM's, Pump shell fuel.
After buying this car and the engine died a week later its nice to see him do well with it.
He is about to post the vids and time cards inc a near full track 2wd burnout. Must be one of the fastest GTRs on real street tyres not drag radials.
Going back on slicks to see what it can really do.
https://www.sau.com.au/forums/topic/174904-rockogtrs-104-in-queensland/
This car is psycho. I just hope he doesnt kill himself in it! Apparently the crowd went nuts when he lit up 4th all the way down the 1/4 haha! Back to Willow Creek with slicks so I hope the gearbox holds up for it!
  • 3 weeks later...
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
