Given there is no car on the HPI drag list that comes close to that 60ft
and we are talking 8 second cars on street drag radials this seems very strange.
http://www.hpi.com.au/drag_records.php
There are cars doing 1.3's in the world but none on true street tyres that I know of !!
The all use drag radials and a good 1000 to 1500 hp !
I mean no offence but I think you gotta look at this logically.
If true this could be some sort of world record.
So let me get this correct Butters, you claim the car is 1000-1500rwhp and must be on drag radials at least? I think by the photo's we can clearly see they aren't any big flash drag slicks on there.
I will let RockoGTR come on here himself and maybe he has a couple of photo's that clearly show the car was on Nexen street tyres, just as it was sent over with. He will be putting slicks or drag radials on it next time, then hopefully the box will hold together and it should go quicker.
This car is DEFINITELY NOT 1000-1500rwhp either, it was nowhere near that.
I will let him no it might be a record and he can inform HPI and show his time slip and join the ranks :thumbsup:
Also bear in mind this car still has full interior and is a comfortable daily drive.
Edited by R31 Chick
I don't want to be taken out of context on my comment above so please allow me to clarify.
I think there is something being done differently to most every other GTR that goes to the drags in some department. Whether it's just a perfectly balanced launch from an outstanding driver or some tricky suspension settings, it's incredibly rare to see a 1.3x 60' time from any street GTR and it's especially rare for it to happen on streeters.
I'm not doubting the tyre choice at all when I say that I reckon there's more to it.
Great job though.
The car is extremely well set up from good suspension, good HKS exhaust, good turbo choice for the car, good tune, good driver etc. There is no NOS or any "secrets" on the car and I am sure Jeff would be happy to show anyone. We aren't trying to claim this figure from a stock car and we never mentioned suspension set ups etc... even tho the suspension isn't anything over the top or expensive. It doesn't have coil overs or anything.
There is no denying the figures, its just a very well set up car that anyone with any knowledge could build on what is not a huge budget.
As I am not the guru on the car or a mechanic I think between Jeff, NIB and RockoGTR they can answer all your questions. Pity they are all holidaying or away working.
Edited by R31 Chick
I don't mind being taken out of context ... seems to always happen on the net lol
R31 Chick you need to take this less personally, are you his girlfriend ?
I am sorry I believe with a 1.3 60ft if he puts on drag slicks he will not go stuff all quicker.
Did he manage to run another pass with a simular 60ft or is this a once off ?
I'd be keen to see it backed up at another track like willowbank If he does its quite an acheivement taking down the likes of keir wilson and theo woollett to the 60ft !!
He just sneaks into tenth place on HPI list, so well done on that !
Nope, I am his ex. Things do go out of context and being Steve's daughter I know this all too well. As my brother built the car is probably why I jump to its defence.
The car will be at Willow Bank soon. There is video footage of the car in rear wheel drive smoking 4th although Jeff hasn't sent it to me yet which will prove the tyre debate.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
