My turbo is back up for sale.
It is an R33 RB25 turbo highflowed by GCG. It comes with both the RB25 exhaust housing and a VG30 exhaust housing.
I had the VG30 housing machined and fitted to the turbo by GCG last year, I asked them to look over the turbo and they gave it the thumbs up.
I have owned this for approximately 18 months but it never made it onto a vehicle I own. Previous owner had receipts showing the turbo was highflowed only 3 months prior to me purchasing it.
Why is it back up for sale?
I sold it to a member of these forums, and being the nice guy that I am I gave him a warranty. He decided the turbo was defective and has returned it for a full refund.
Reason?
There is a small crack in the housing on the ring of the wastegate. It was taken to GCG by the purchaser and they called me to discuss.
As it is they said it wont affect performance, but may deteriorate over time. Given this the purchaser decided he did not want it.
He told me GCG offered to fix it for ~$120 if it would make him feel better, but he was not interested. (I assume they would weld it)
I now have the turbo again.
The deal!
I'm not a shop, so from now on there is no refund or warranty. If it was a brand new unused item I would be happy to oblige, BUT this is a second hand highflow built from a turbo that is ~10 years old. I will post pics of the VG30 crack tonight so there is no confusion. I will also post pics of the RB25 housing and a hairline crack (only visible on inside not outside) that also concerned the purchaser, but I believe to be normal in a housing of this age.
The pics
The wastegate crack
Rear wheel and housing
Compressor side and wheel
Pictures of both housings, you can see the size difference
Hairline crack on RB25 housing
OP6 goodness!
Turbo was sold for $1400, given all the f'ing around and the crack in the housing I'm letting it all go for SOLD pending full payment
https://www.sau.com.au/forums/topic/174921-gcg-hiflow-vg30rb25-hybrid/
hey,
wat sort of power did this turbo get.... wat is it rated hp wise.... is this better or equivalent to a garrett aftermarket unit such as GT3071R, 3076R, GT500- 500hp internal gated turbos. also is the entire unit ball bearing.
thanks
Hey johnabs,
Turbo info can be found here;
http://www.gcg.com.au/Catalogue_Menus/Upgr...pgrade_gtst.htm
I would anticipate 250 - 280 rwkws depending on your supporting hardware.
Lots of very nice offers on this turbo already!
PM sent.
By the way: Did you copy my Avatar? :thumbsup:
Just to let ppl know. I previously had a similar turbo on my car. It made 270rwkw@15psi, on a rb25 with Tomei cams and head porting. I sold it because i "thought" it was laggy, but after having similar response issues with a HKS GT-RS, i found that i had a restrictive exhaust. So this turbo combo has "similar" response to a GT-RS, but makes more power, at the same psi. The hi-flow is now fitted to a standard rb25NEO and is also making 270rwkw@16psi.
i believe thats what GCG tells us what to expect, but what did this particular turbo make in regards to power on ur car on wat psi and wat mods did u have. A mate had a gcg rb25 (not vg30 rear) and made 235rkw on 18psi or so, as they have very restrictive internal gates. do u have dyno papers to prove the power- do u need cams to rear the 250-270 mark.
Mate, the turbo never made it onto my car. So I have no graphs to prove the power to you...
There are alot of debates about how much power these and many other turbos make.
I cannot offer you a definitive response, although I can name many people with over 260kws using this turbo.
Hope the same avatar does not confuse you, so just look at the user name.
I also do not know Drew, but just have bought his cooler kit (Transfer of funds complete Drew :thumbsup: )
The internal gate does not restrict power :ninja:, whoever told you that has very little understanding of turbos. A small internal gate will only produce uncontrolled boost creep, because it can not expel gases fast enough thus the turbine spins faster, resulting in increased boost.
235rwkw on a std hi-flow, bolted to a std rb25 is about the limits of this turbo. With the bigger ext. housing, and all the supportive parts 280rwkw (my personal experience) would probably be the max of this turbo. Sometimes a turbo will max out at 16psi, sure an extra 2psi will get you an extra 5kw, but the gain per psi is reduced, thus not worth stressing the engine for 5kw. This is caused when the turbo's efficiency range has been passed, so the turbo creates too much heat, thus reducing the power gains.
Turbo back up for sale, read all about it in the first post.
If you plan to buy it...
Don't agree to a price on the phone and then bust my balls when you arrive at my house.
Don't ask for an unreasonable warranty on a second hand car part.
Do make sure you can afford the item you are buying.
If you want a brand new item with warranty, save up alot more money and buy a GTRS kit or the like.
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
    • I've never done dial in's just straight up, whatever that's called. I'm far from a drag (racing ) expert.
