Stock picture of car in the shop.. cant get a newer pic cos its getting work done at the moment
Can someone please try and colour in the dark grey at the bottom of the car to the cars colour ? Thinking of spraying it and would like to see how it would look
Edit: Sorry only pics i have
Thanks, Leigh
Edited by leighzor
https://www.sau.com.au/forums/topic/174931-can-someone-please-photoshop-this/
i have a two tone also (2door) i was gonna get it resprayed also, then i decided to get some new rims/tyres first and see how it looks, now i don't want to get it resprayed or a new bodykit put on, i would go with new rims first and see how you like the car and then decide
