  • Replies 93
hey funky,
can only find the torrent for eps1 and 2 :P
if youre checking my suggestion of going to anime suki, then yea they only have the first two.
use a keyboard. Thats what google is for.
lol i did but could only find the eps1 and 2. Im playing the ps3 game and its all in Japanese, so i cant understand the story line lol need to watch the anime to get up to speed
TV-Links has the first two episodes up too, not sure how good they are quality-wise, but I'm about to find out. I guess I'll have to use YouTube to see the other episodes for now.
the stories a bit creepy isnt it?? i mean..who REALLY talks to their car like that?? actually, who talks to their car AT ALL??
bloody ijjit. he gets his car flogged not once but TWICE by two chicks and both times right in front of him!! And he sits there all..Im the man Im the man..dont trash my car man, but if you do its kewl...
didnt someone just say that initial D story line was crap?
considering this is from the same studio house, thats a compliment. :closedeyes::P
Umm... Up to Ep.6 Part 1/3.
Need 2/3 and 3/3 if anyone knows where to find?
With subtitles please :domokun:
wtf? mate check you tube, its up there with subs..
type : wangan midnight 6.
Does the show get less annoying and stupid?
As wanky as they were, at least Initial D talked about driving techniques and other junk like that.
The most airyfairy they got was with the car's "aura".
But Wangan Midnight was just ghost cars and a guy being a jerk to some chick he has had a crush on for ages... does it improve?
they are all RAWS for me. Without subtitles.
Wtf?
You need the SEVS one.
Thank you!! I'll be here all week!
I actually watched that movie... it was soooooooooo bad
But it didn't quite make that loop around to being so bad it was good again...
I need to finish the review I half wrote for it.
Edited by Laurence
haha shuto trial was da bomb! wasnt that the one with tsuchia (iono how 2 spell his name...aka the DK~) and u get to see a silvia and an fc go drifting? lol if its the same movie, dammit it was pretty cool hahaha
just out of curiosity, does anyone have any copies of シャコタン ブギ or Shakotan Boogie?
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
