MAKE AN OFFER - POSTAGE AVAILABLE TO ALL STATES - PICKUP AVAILABLE: BRISBANE (SOUTHSIDE)
R32 instrument cluster:
$50 $35 + $15 delivery
87,000kms on the clock
blue dials
pic:
R32 Speedo cable:
$40 $30 + $10 delivery
no pic unless requested - off car with low kms.
includes the springloaded shaft that interfaces with the instrument cluster.
Autometer Sport-Comp A/F Ratio Gauge:
$50 $40 + $7 delivery RETAIL ~$150
wiring included (3 wires: +ve, -ve and signal from 02 sensor - easy install!)
pic: http://www.autometer.com.au/images/brands/...eter/AU3375.jpg
AutoGauge, 5 inch All in One gauge:
Smokey Screen, Black when inactive - NO SHIFT LIGHT
Shows: Boost (bar), Tacho, oil pressure, oil temp, water temp, battery charge
I have oil temp sensor, water temp sensor, boost sensor (elec), but NO OIL PRESSURE SENSOR
$80 $70 + $10 Delivery COST ME $190 6 months ago
Swoosh Boost gauge (<1.5 bar):
Is either 2" or 2 1/4" in diameter, mechanical, includes 2m of quality 'blue' boost hose
$25 + $7 delivery
Speco Oil Pressure Gauge(psi):
includes sender (elec)
$15 + $7 delivery
DONT MAKE WAR _ MAKE OFFERS!...
Edited by kristafa
pics of the speedo cable - yes please...
where in QLD are you?
edit - I see you are southside bris.... (what suburb??)
Edited by insanity
i am interested in the R32 Speedo cable-- includes the springloaded shaft that interfaces with the instrument cluster., my speedo is messed up and i think i might need one of these.. ill have a look first just to be sure.. ill let you know asap..
cheers, tushar
new stuff added
probably add some more stuff tonight too...
- r32 stock crossover pipe + stock BOV (swap for somebody else's aftermarket BOV + cash?)
- turbo intake pipe and stock BOV plumbing
- .. and more
chris.
more stuff:
- crossover pipe + stock BOV $40 pickup only
- turbo intake pipe + stock BOV plumb back piping $20 pickup (+$20 delivery, fairly big item)
pics look good.
consider the speedo cable sold then!
please pm me your details.
I should be able to pick it up thursday evening (about 6-7pm).
cheers,
Beau
update:
Instrument Cluster - SOLD [pending payment: madaz_R33]
Oil Pressure Gauge - SOLD [pending payment: XtremeChief]
Speedo cable - SOLD [pending payment: insanity]
Good price for the speedo cable. They retail for $130 brand new!
Cheers. Just looking for some quick sales so i can tidy up a few loose ends with my engine conversion.
Edited by kristafa
Instrument Cluster - SOLD [paid: madaz_R33]
A/F ratio gauge - SOLD [pending payment: tosboost2]
Edited by kristafa
Oil Pressure Gauge - SOLD [paid: XtremeChief]
Speedo cable - SOLD [paid: insanity]
A/F ratio gauge - SOLD [paid: tosboost2]
new prices:
5" all in one gauge = $60 + $10 delivery
52mm boost gauge = $20
:bunny:
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
