My poor car
Guest 382 GZV - 4 Door R33
I know this has been talked about in other threads but now I can't find them when I need them most!
My car has developed a machine gun noise (a small jerking in the acceleration) above 5000rpm in any gear. My car is standard but for exhaust and K&N panel. At this rpm, the car is reading 9psi at the manifold.
The only two things I can think that may have triggered this is 1. I hit the speed limiter the day before, 2. I tried hooking up a boost controller (which I later took out) and wired it up wrong the first time - the car reached a maximum of 11psi but was immediately fixed....I tested the fuel pressure, spark plugs (replaced them with ones we know work) and resetting ECU but to no result.
Please someone help me!
Steve
https://www.sau.com.au/forums/topic/17500-my-poor-car/
Steve It still feels like a boost cut to me though I don't know why it should come into play at only 9psi.
Have you figured out how to run the diagnostics yet? If not give me a call and we can organise to do it. Another thing we can try is swapping in my boost control solanoid to check if yours is faulty....we should have thought of that the other day.
When is the fmic and pod going in?
https://www.sau.com.au/forums/topic/17500-my-poor-car/#findComment-362142
my car use to do that, its non turbo but i dont know if that makes too much difference. I recently changed the fuel filter and there is no problem now. I dont know if it was so dirty or sumthing it was clogging up but its done me well. I also put injector cleaner and additives in the engine oil cos it was developing a knock which has also gone too
https://www.sau.com.au/forums/topic/17500-my-poor-car/#findComment-362783
The plugs I put in were gapped to .8 and I only have stardard boost (reading 9psi @ manifold).
I thought they had to change the fuel filter when they comply the car - it was complied end of Feb this year.
Jay -
Yeah, we should have tried your boost solenoid. I have tried to run the diagnotics but I couldn't find the screw/dial I'm spose to turn to begin the diagnostics.
The FMIC goes in on Monday next week (hopefully it's not delayed any longer). I have got hold of the adapter plate for the pod. I will drop round Saturday to pick up mick's pod and hopefully fit it before going on the cruise.
Steve.
https://www.sau.com.au/forums/topic/17500-my-poor-car/#findComment-363406
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
Ă—
Ă—
