Autosalon
thirty four
 Share
with autosalon coming up soon i was wondering if anyone is planning on entering, to be honest i dont think it is anything that special but do like the whole concept of it all and its something i have always wanted to enter and if we were able to organise a display of skylines would be keen to be apart of it, anyone else possbily keen?
  • Replies 309
I was speaking to Martin (Hostile) about this yesterday. Aparenlty PKBlade and *flick* are organising an SAU display? guessing one of them will post in here, if not, try sending either of them a PM :domokun:
I believe that all cars have been organised for the SAU display but i know we have had a couple drop out.
So i would email PK ASAP to see if we can get you in the display and get your entry form in ASAP as if you dont meet a certain cut off it will cost you $240 instead of $70.
Cheers
Shaun
Thirty four you have a PM.
As a few others have said, Pk and i discussed and decided to put together an SAU display for Autosalon this year, and we have also had a few drop out.
Trimming organised... check
How much are deals going for???? :laughing-smiley-014:
huh? :dry:
I'm on here almost everyday and haven't seen anything mentioned about autosalon!!!
I guess its just an exclusive thing then!
Yeh must be....... Meh i wont even be going to the show, same shit different day!
mmmm, know how to join this exclusive club Darren? :domokun:
make ur car look btr than it goes
So rice it up so you cant drive it on normal rds and when you do it goes slow as lol....
nah i will stick with enjoying the real pleasures of a skyline, power and handling...
Who wants to be in the exclusive club of driving your car and being able to enjoy it with stupid power, daz your vice president and ash you can be secretary lol....
i drive my car everyday....but yes....it is slow :domokun: i still enjoy it though
i miss stupid amounts of power last car 240+ rwkw the 32.... 120 rwkw haha :laughing-smiley-014: but ive only just started :blush:
Edited by Import S13
Was going to finish touching up a few things on my 33 to make it almost show room condition. Guess there's no point in rushing out to get it done if all spots are spoken for though.
i believe there was going to be a thread put up about it and there were still gonna be opportunities for others to enter, so if people are interested maybe say so and post a pic of your car with your post?
oooooooooowwwwwwww, thems fighting words. I'd rather have a fast silver bullet than a slow yellow banana. :thumbsup:
atleast i know how to fill my gaurds, i should head over to ns.com and get my T.O.P. approval! :O
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
