Autosalon
thirty four
 Share
what is the point of havin all the cars in the display with high kW's when they are not going in the dyno comp
on that topic is anyone in the SAU disply going to do the dyno comp???
  • Replies 309
Want to say Well done to Flick and PK for sticking there hands up and wanting to put together a display at autosalon..Its a big job and need all the support and cooperation and help from SAUer's
I did it for Sydney not that long ago and its a massive task and was hard enough over here as most are over the whole bling thing...
SAU NSW had not had a display for 3 years as most pulled out or no interest at all but finally got 11 cars together and we did the best we could...
Its all suppose to be fun...so try to go easy people
We are all here for the same reason and its not who has most kws or most bling its suppose to be about coming together and having fun and doing something you enjoy..
Jess
From what I've seen of the cars entered, there is a good spread of power and cosmetic mod's. Something for everyone :dry:
Well, we're fairly closely aligned then, Dan. I'm a RAAF Avionics Technician - pretty much the same as an ET in the Army. I'm at DSTO (near RAAF Edinburgh). The unit I'm with is Tri-Service (Army, Navy and RAAF) and surprisingly enough we regularly liase with the guys at 16AD Woodside (RBS70 sim' and info').
Yep lol well im a RBS70 tech lol, that sim is a pain lol.
And MISSR34 thats like saying whats the point in a non turbo skyline lol.....I like to look at the work thats gone into both exterior and especially under the hood of a car, nothing better than looking a a T04Z hanging off the side of an RB26.
nicely put, couldnt say it better myself.
i totally agree
eeeeekkk!!!!! sif let someone sit on your car?!?!?!??!! i hope she had a really nice arse!!!!! :D:D
and isnt she kinda short?? (no offence, i like short chicks, their normally more fistey =P) but dont taller promo girls attract more attention? or are we going for quality not quantity?? :) perhaps the voting was done florida stye, rigged from the inside i tell you!!! its all rigged! i could swear i voted for the leggy brunette!!!
ehhh only car, shes tall enough she was just maggot in foto so was leaning over fair bit
her brightness will attraked em i now id rather look at her than sum taller chick that is up her self
G'day Andy. It's been a while mate. Love your 'new' car.
A Bridgestone VIP hey, Pauly. Hmmm... I'm in need of a fresh set of RE55S :D
Dan, you have e-mail. I found you on the work system (unless there's another CFN Dan SXXXX at 16AD)
lol, tis all good!!! =P
like i said, quality not quantity =)
Hey whatsisname
The pics of the car look good, very tidy, cant wait to see it at Autosalon.
Looks a lot different to last time I saw it :thumbsup:
Simon
I wouldnt bee too keen rushing to sign up 4 autosalon no matter what car i have...just look at how many lines go missing...AS is a good opportunity for a potential thief to check out your car...
Matt is fine, his car is never running to be stolen, or at his house!!!
:whistling:
Looking forward to viewing her in all her glory.
Ha-ha. Harsh, but oh so true.
Me too mate! See you soon.
  • 3 weeks later...
Work has decided to enter a 300C SRT8 Wagon into the show :ermm:
it has been lowered, big exhausts fitted, 22" rims waiting to go on it.
Tv's put through it and last i heard it was getting some vinyl's on it.
It has some nice 20% tint on it aswell :laugh:
Hoping to get down there on the weekend
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
