For sale is 1 used Apexi power fc this unit was purchased from Sliding Performance (Aaron Peters) on the 16 th of april 2007... i payed $1500 dollars for the computer hand controller and boost contoller kit...it has never been fitted to my car only when 1st arrived i plugged it in to test it..thats all i must sell this due to a financial situation i am in :domokun:
Power fc serial Number:pfc rb25 9710-0058
i am asking $1500 o.n.o delivered
bank: Suncorp Metway
mitchell cole
account no: 160937622
bsb number:484-799
this will be sold saturday if old mate comes through so get in quick if you want it
and no stupid offers everyone knows what they are worth and how hard to find a good condition one so please no silly offers.
its not to high....there are pfc without hand controller going for 1000 bucks this has contoller and boost kit
u got cash i got a power fc....its your call
:D
Completey fair price if you ask me.
You'd easily sell the stuff seperately too if you wanted.
Some PFC's have sold for $1500 for the R33 so good onya and be patient.
Completely not interested in the sale as have the R33 gtsts PFC with the boost controller too and love it.
Highly recomended :) Good luck bud.
I never said it was expensive it's a great price for the kit, but if you don't ask you will never know. LOL.
As much as i hate to have a PFC, it seams like the only thing that would stop my current issues.
Hay mate, if you remove the Boost kit, and sell it for $1200 ono i will take it off your hands, or we can do a swap and cash adjustment to you. I have a central 20 ecu and a SAFC II making 217 rwKw on stock turbo. ECU can be remaped and DR Drift can do these now. The SAFC II is 9 months old and the ecu was purchased 5 monthc ago.
The Ecu is an R33 remape ecu not R32 as is commonly used.
If you are interested let me know via PM. For swap the ECU and SAFC II would be $400 so that is $1100 cash adjustment. Or we can talk about just the ECU and so forth.
Thanks
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
