Just wondering if there will be a noticeable difference on a stock turbo (R33 11psi) between a split dump, and a split dump/front pipe (where the split joins to the main pipe further along)? What is your experience?
Also, do you guys always heat wrap your stainless steel dump/front pipes? Is it required/advisable?
Another thing, i noticed when i put my highflow cat on, it caused richness. Will i find the same with going from standard dump to split dump? ie, requires a retune?
Cheers
EDIT: i currently have a stock dump going into a 3 inch front pipe - 3 inch cat back. very straight thru exhaust. hardly a bend in it, with a cannon on the end.
Edited by Munkyb0y
you wont see anything noticeable b/w front dump and split dump. IMO, and others will agree, either a front/dump in 1 from flyn. or a jjr split front/dump will be exactly the same.
unless ur targeting more than 250rwkw, then either will be ok. if you want more, go a the front/dump in 1 like flyn has.
the longer wastegate sepparation on the split dump design improves power, due to reduction in turbulence at the turbine exit. This is well proven on the GTR, with products like the Trust style setups. The gtst is going to benifit in exactly the same manner. If you look under the forced induction 'guide' sticky there is a back to back dyno of the improvement on a fairly stock gtst, as proof if you need it. The theory is sound enough however.
I recently aquired a JJR split pipe for my stagea (Rb25det), it needed a die grinder to clean up the alignment of the flange. IT was cheap so some elements of it's finish are what you expect for the price.
I usually heat wrap the pipe. Be sure to do it properly, with even overlap of the tape. DEI make a tape that has a line marked on it as a guide.
Edited by rev210
There was alot of discussion about this a few years ago when BATMBL introduced his pipes into the market and was competing against CES... as rev210 said the longer wastegate separation the less turbulence.
I currently run an apexi front pipe and stock dump. Wouldnt mind changing over to a BATMBL pipe when I put my new turbo on though....
thanks for the replies
i'm still tossing up whether to keep my current 3inch front, and just add the split dump to it.
but after some more research, it would seem that to gain most benefit from a split dump pipe, the split should be a minimum of about 40cm before joining back to the main pipe. so i guess a split dump/front pipe is the way to go.
Make sure 100000% it is...coz my friend's joins almost instantly (shit custom job) and now he has a brand new engine...cooked. (couldnt lower boost in the run in period). Otherwise, if done properly, i personally think they are the way to go.
guess he drove with his foot down too far then! :(
This is my opinion only but I reckon you lose a bit of convienence if the dump/engine pipe is in one piece . The turbine housing outlet/dump pipe bolts can be a pain to work around in situ and I have to wonder if removing a turbo with the dump attached would be easier . You can get at the fasteners easily enough once the turbos been removed .
Also if you needed to remove the engine pipe alone for some reason its very easy to drop- it off the bottom of a conventional dump pipe .
All up to you guys but making things straightforward to work on saves knuckles and time in the long run .
Thoughts ? Cheers A .
I reckon you have a good point. But I think most people when they were shopping for exhausts like I was too at one stage, only thought about the 'fit and forget' side. I haven't had to remove mine again thankfully.
But if your going to be removing and refitting the exhaust on a regular basis, having a separate dump to front pipe certainly would be more convenient.
Getting to a couple of the bolts on the back of the turbo are a bit hard to get to but they're not impossible. Having a friend on hand is a must whether its a separate dump or not & it makes things a lot easier.
I would agree that removing the turbo would make it heaps easier to remove the dump, but it then involves removing more things in the engine bay, like undoing the turbo to exhaust manifold bolts, water line, oil line, hot intercooler piping, pod/airbox, intake pipe and afm.
By the time you've had all that off, you could've removed the the heat shield and O2 sensor and dump & front pipe.
It's not a bad idea, but it just depends on the cars duty's as to what you use.
Cheers.
so u saying an extremly small dump pipe wotn effect boost ?
*should have probably mentioned his injectors were f**ked :(
You say that the small dump pipe meant your friend was unable to 'turn down the boost' during his run-on, and in turn this is his excuse for blowing up his engine. This is one of the most ridiculous comments I have ever read on SAU.
Blaming an undersized dump pipe for overboosting and blowing up a new engine............. :laughing-smiley-014:
Sounds like your friend leaned out his motor, either due to an injector problem, poor tune or too much boost - This has nothing to do with his split dump pipe and is completely irrelevant to this thread.
Who said i/he was entirely blaming the dump pipe ? I just said it played a part in stuffing up boost levels and as well as his injectors weren't too good causing, like you said, the motor to lean out and go bang.
And no he wasnt giving it too much, it was still in the run in period (obviously gave it a bit sometimes, but not constantly).
So its pretty much what you said, too much boost, shit injectors....How is that the most stupid comment ever made on SAU ?
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
