things to consider.
there should be no wire on the loom for pin 51 if there is no traction control on your car. having spoken to EGA4IT and he says he has seen one car (maybe a later model with a wire in the loom). he said the zener diode is not in backward on the diagram they are reverse polarity (i hope i am translating accurately).
regardless of whether you have a wire or not, you are trying to fool the ECU into thinking there is 3.7V so it 'thinks' traction control is working.
if this modification is made you need to test that the voltage TO pin 51 is about 3.7V or else you have made a mistake.
if the checklight is still on make sure that the boost controller is turned off on the powerfc as this is the usual reason the checklight stays on when first installed.
Edited by wolverine
Thanks for that, Ill give that a go...
I just tried to turn the boost control off but of course it is in Japanese so i am assuming it is off at the moment as it has a diferent japanese character to the other warnings which i am assuming the tuner left on..
Thanks again to all for your help
Dave
things to consider.
thanks mate, that explains everything
nice and easy, cheers again
thats what my mechanic said that you cant get the exact ohm stated resistors
it doesnt have to be exactly 400 ohm, it could be 500 or even 300 ohms, the idea is to provide a reasonably high resistive path back to negative so that current does not flow through the ecu in the event of some sort of failure/short.
also the zener diode needs to be installed in reverse bias. your auto electrician should know what this means.
thanks andy
awesome news
cant wait to hook mine up and 'see' what happens :D
  • 8 months later...
  • 8 months later...
i have had a few pm's and just thought id add a quick note to prevent confusion/frustration, if u cant find a 10.3V zener diode you can use multiple diodes that add up to 10.3V as long as they are connected in series
  • 1 month later...
Hey Guys,
Having some trouble with my powerFC. My car to clarify is a ER34 (R34GTT) that has had a conversion to manual. the powerFC throws up a backlight on the THR sensor with a voltage of 0.00. The car runs perfectly after an init clear. however I have some problems. MIL light is always on, TCS light is on and cannot be toggled with the TCS switch on the dash. the Aircon turns on but the compressor does not and last but not least HICAS light is also on.
any ideas if my series 1 R34 has the same problem as the Stags?
Cheers.
  • 3 months later...
  • 2 months later...
  • 5 years later...
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
