Got the car back today and engine light is now out. Auto sparky fitted a terminal to pin 51 and followed wiring diagram for diode and resistor placement. Cheers. Car is a 1997 S1 RS4 auto converted to manual using a power fc for a r34 gt-t for future reference.
Yep, mine is pretty much exactly the same: 1997 S1 RS-Four V converted to manual by the previous owner, then I had the R34 GTt PowerFC with "secret squirrel tweak" done.
Ah yeah, I do remember having issues with that, now that you mention it. The conversion was done a long time ago, so I can't remember (and don't actually remember being told) what was done to fix it.
I think when I had it done it was mid-summertime too, hence my requirement for working air-con.
  • 1 year later...
Does anyone have the info on supplying tps signal to the attessa ecu to make the 4wd to work with the power fc? Mine has never worked since I've had the car. Have the pin 51 mod done and bled the 4wd system, pump primes and I'm not getting any lights in the dash.
I'm assuming it's the tps signal anyway
http://www.sau.com.au/forums/topic/464561-stagea-engine-conversion/
Heres some relevant info. You'll have to check whether the power fc outputs the voltage to the attesa.
If not then you may need to employ some electronics skills, ie, you could make a splitter for the TPS so it supplies voltage to both the power fc and attesa, however you would need a buffer circuit to ensure that there isnt a voltage drop caused by connecting the sensor to multiple devices.
  • Like 1
Cheers. That's a good bit of info and helpful suggestion
  • 6 months later...
Ok, so I have correct tps at attesa ecu. What's next? I can get the pump to run for approx 5 or so seconds with the bleed plug in the kick panel disconnected. However, it doesn't prime when ign is switched on. Could it be a faulty accumulator?
  • 6 months later...
Great thread, just so that I'm in the the clear. I will be removing the NA engine and dropping a RB25NEO AWD from a Stagea into a R34GT-4.
I'm going to throw out he GT4 ecu and use a GTT ecu. To be able to retain the Attessa. I should split the TPS signal into two. One goes to the ECU and one goes to the ATTESSA.
I will be running a Link ECU is it any different to a Power FC in terms of the trick mentioned above?
Did you guys have to purchase a new wiring harness to be able to do this?
Pretty sure the Link goes into the GTT case - you may need an auxiliary loom for the IAT sensor and maybe the Map sensor
Yes it's a plug in ECU. I was worried if it is possible to do the same as covered here for the PFC. I have a map sensor and IAT ready. They connect on an XS loom.
  • 1 year later...
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
