I still think he knew about the dump pipe.
no doubt about it - someone on the forum must've leaked the info!!!
then again it could've just been an angry driver of an is200 who found out i ploughed his wife. don't worry man, i was very considerate and i know the rules - up the bum = no babies :thumbsup: s'all good.
  • Replies 72
roflcopter...I'm an A grade wanker to A grade tools...Josh and I have that in common...you all <3 us though!!
Hugs all round...except for you Mark...you and your freaky coconuts stay away :thumbsup:
Hahah, its true. We have such an A grade wanker skill dont we Matteh
josh is cool..
keegs u really are a wanker..
Unfortunately you only believe this because you're an A grade tool, and as previously mentioned...I have a compulsion for being a wanker towards A grade tools. Take a tissue and build a bridge marki.
... tsk tsk.. indeed school holidays are in.. buidling up ur E-wang are we..?? also ur such a mighty key board warrior!
Taking things a little to seriously are we? Getting a bit cut up? Don't self harm tonight Marki, razors are not your friend.
asif black ppl cut themselves yo.. dont u white ppl with ur depressants cut urselves... i dnt knw why ur sad.. ur white... SMILE.. think thats off the longest yard.. haha
your all a bunch of f**ken heros hey lol
lol.. :) great post..
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
