I just wanted to separately thank all the helpers who made the Show 'n' Shine such a success.
In no order at all:
Doodzzz
Linksmeup
Druncan
Kelzer
ULOOOOOOOOK
Munkyplunkit and GF
Ozsoldmy02GTR
GowellShell
Lizajane
SinfulN!R##GTR:D
Nutzinpockets
Goldigger and Cozy
TJimaganitivenickname and family
NXTCAR
evilchubs
DJwayno
Blitzkrieg
JASno25T and GF and cousin
DIFrentstrokes
Riskinhissanity
INSAIN
ELU-hs-U_N- for pics
Г-н мÑÆ’ÑоÑ€нÑ‹Ñ… мешков (edit: haha computer didn't like that one Eug)
Just Jap
Pro Speed Racing
Brad's Custom Trim
Toyo Tyres
Unique Auto Sports
High Performance Imports
Pro Coat
Sliding Performance
Whiteline Suspension
The Toy Shop
Motul
Xclusive Colours
TMAutosports
GCG Turbochargers
I can guarantee I've forgotten someone or some people but the point that shows above is that heaps of people helped and made it happen. Without you guys it wouldn't have worked so thank you very very very much.
Also, thanks to everyone who polished up their cars and entered. Champions all of you. :)
https://www.sau.com.au/forums/topic/175081-thanks/
Also, thanks to everyone who polished up their cars and entered. Champions all of you. :thumbsup:
How are you still president??? :O
:D
https://www.sau.com.au/forums/topic/175081-thanks/#findComment-3211210
Nutzinpockets
:laughing-smiley-014: adam you just cant bring your self to say my name ahahahahahah
Thanks to all the judges I am sorry if I was unable to thank you all but I think you all did a wonderful job. :thumbsup:
And I cant forget the cooks man that was a awsome bbq :O:D you get two thumbs up for that
https://www.sau.com.au/forums/topic/175081-thanks/#findComment-3211534
I had a great day. I love telling people where to go (park) :)
I think I speak for all of the helpers
It's our pleasure!!
Thanks to everyone that helped, all the sponsors and ADAM!!!!
Oh that was you! i thought some random, done with breakfast at maccas, put on a fluro vest and enjoyed the power :)
Can't be pres without pissing someone off. :)
I didn't vote for you...
I voted for the other guy :O
https://www.sau.com.au/forums/topic/175081-thanks/#findComment-3211986
As everyone has said, always happy to help out..
Everyone did a fantastic job!!
Hey Links!
Was your car there coz I didn't see it..... I was looking for another 40th A/E at SnS but couldn't find one..... :D I've only ever met one other person with one so far.
https://www.sau.com.au/forums/topic/175081-thanks/#findComment-3212434
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
