hi all
i am about a tenth of the way throught my rb25 conversion on my r32 and thought tonight i may put the fuel pump in. i brought a bosch 040 pump a week or so ago as sofar my 32 has seen little in the way of engine mods and the new engine needed some more fuel.
i un-screwed the cover and to my suprse the 040 looks nothing like the old pump and doesnt even look like it would fit in the cradel properly. i had a quick look at it to try to work out how i could fit it in but then thought i would just come and do a search on sau but i havent found anything so now i am asking the question? does some one have a how to. i also checked in the stickys and the only fuel pump ones were for increasing the voltage.
so could some one please help me and explane what they have done.
i have a suspision that people just cable tie the pumps to the brackets and that why all the skylines i have ever been in with AM fuel pumps have been noisy.
if no one has any info then i may write up my owne tutorial to help others out.
thanks damien
https://www.sau.com.au/forums/topic/175083-bosch-040-fuel-pump-instal/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
