hey got these the other day 2 technics 1210 mark 2z an a pioneer djm 400 an audio-technica LIMTED ED head fones
rite now im mixing around with dnb an think im not to bad at it any one else out there mix an is so wed nite im mixing at mine prob with a few other mates that do hard house etc
Edited by 4dirty2
https://www.sau.com.au/forums/topic/175094-my-new-babys/
Nice!
i got a djm 600 , a pair of cdj 700s and a couple of old technics 1200mkII's.
i play mostly Progressive house with tribal and a few breaks...
hows your beat matching, stage matching and EQ's coming along ?
shit haha nar gettin there havnmt found wat i want to mix yet started dnb but swiging to trance. u down south
That's sweet! I'm looking at getting into mixing so if anyone has some old decks and gear to sell let me know!! :domokun:
go into derringers (spelling) behind wayvile show grounds an get them to hook u up a deal theres a stanton lab 3 pak there for 1100 great beginers pack
mine cost me 2700 all up stil gotta get sum btr speakers if any one has some old technics out there in a shed hook my way for $$ or beer
Edited by 4dirty2
https://www.sau.com.au/forums/topic/175094-my-new-babys/#findComment-3210788
Mmm a grands a bit much just for a bit of fun. Maybe if anyone out there has their old gear lying around and wants cash or beer, let us know! What DnB DJs are you into?
what you should do Hillzy is hire your self a small mixer and a couple of decs from Derringers the place 4dirty2 mentioned its fairly cheap :)
4dirty2 I did used to live in Moana when i started... but now move to NSW :D. i miss my beach
Just wondering if you know a guy a derringers called Lynton. I would like to find that guys for a bit of a chat and a price ona few things.... practice practice
https://www.sau.com.au/forums/topic/175094-my-new-babys/#findComment-3212159
nice work
love my trance, nice uplifting beats.....
dont find time to get into mixing etc, although years ago I made a few basic trance tracks on some PC programs, havent tried it for years tho; damn you life !
https://www.sau.com.au/forums/topic/175094-my-new-babys/#findComment-3212338
I started mixing when I was really young. At first I was just into scrambled eggs and omelettes but later progressed into cakes and cookie mixtures. As I grew older though I moved to a genre I call cement. Here are some of my equipment:
https://www.sau.com.au/forums/topic/175094-my-new-babys/#findComment-3212386
i was a cornice fixer, i thought i was killa cause i mixed cornice cement with a makita 600 drill and a cement drill bit, now i see i was just a noob when u had mixers like that. gdamn!.
Edited by Pauly33GTS-t
https://www.sau.com.au/forums/topic/175094-my-new-babys/#findComment-3212416
what you should do Hillzy is hire your self a small mixer and a couple of decs from Derringers the place 4dirty2 mentioned its fairly cheap :(
as if u moved to nsw from moana arrr ur crazy
nar dont now any one there just wanted to get out of there once i paid so i could use them my mate nows a few ppl from clubbin etc
https://www.sau.com.au/forums/topic/175094-my-new-babys/#findComment-3212656
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
