You have full boost by 3500rpm ;)
Same turbo on a rb2530 is going to be a lot of tyre shredding fun :P I was told full boost (20psi) by 3400rpm, but it may be even earlier.
Any dyno graphs?
No dyno graphs yet. I will post them as soon as they are available. The next motor will either be a fully built RB25 or a RB26 high decked to a RB28 with a 3540 or similar. What ever will rev hard and give me 400ish.
  • Replies 89
Posted Images
Defanitly not taking it to QLD. Staying in Melbs!
Cheese!!! Looking sexy, almost as sexy as yourself... (almost) If you need me to go around and umm... start her up... let us know! Promise I won't poke any holes! :thumbsup:
  • 1 year later...
Thought I would pull out the defibrillator on this post mainly for Brisby as he wanted to see pics.
Recent modifications are....
Alcon brakes
Tinted perspex windows
New bonnet
Vented front guards
New boot
R34 rear end and new suspension arms and shocks
Rear diffuser
Replaced fuel cell with stock fuel tank
Changed rear wheels from 12 inch to 10.5 inch
Aero catches for boot and bonnet
Big thanks to Freddy at Top Stage for the new body work and Mick from Micolour for the excellent paint and tidy up.
Looking to hit Sandown on 25th April to see whether any of it helped lol.
Next on the list is a BIG wing and FRP doors then apart from playing around with the set up its finished.
post-917-1239707631_thumb.jpg post-917-1239707676_thumb.jpg post-917-1239707691_thumb.jpg post-917-1239707719_thumb.jpg post-917-1239707728_thumb.jpg post-917-1239707742_thumb.jpg post-917-1239707757_thumb.jpg post-917-1239707772_thumb.jpg post-917-1239707790_thumb.jpg post-917-1239707807_thumb.jpg post-917-1239707821_thumb.jpg post-917-1239707843_thumb.jpg post-917-1239707857_thumb.jpg post-917-1239707872_thumb.jpg post-917-1239707881_thumb.jpg
do you just have a rear diffuser, or do you also have a front splitter and a flat underbody?
btw. Car is SEX :P
There is a front splitter of sorts and now a rear diffuser. The front splitter is just a sheet of aluminium under the front bar. W plan on making a more areo dynamic one out of carbon in the future.
Exciting.
I wanted somthing that was like diving a 300kw in the wet and thats prety much what its like. You have to think twice before touching the right peddle in any gear apart from 5th lol. But it should be a bit eaiser to drive now which hopefully means faster.
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
