  • Replies 89
Posted Images
speaking of hearing it, it is deafeningly loud, sexy loud, and thats from someone who loves loud, not these gtr girls with their uber quiet exhausts.. are you gonna change it for sandown?
what wing also? v8 supercar? gallardo or 430 GT car wings are huuuge FTW.
Been talking to VOLTEX and they have recomended a Type 2 1600mm with 225mm base. Failing that Freddy has some ideas.
lmao... same bonnet I've got on my 32. D-Max or Viva? Lookin forward to painting mine now that I've seen how sexy it looks. That's a pretty good idea painting the little slits near the windscreen black... mine were all monged up. *yoink* idea borrowed.
you went to town on the front of that BN blister kit tho... looks very abflug style now. nice. looks much more race car like than in standard widebody form.
and thank you thank you thank you for takin off the hektic chromies :P
Oh well, get hm down to Micolour to measure up my car while its all being sprayed :P How do i get in touch with him?
Send him an email [email protected]
Ill let you know how it goes
that thing is a god dam beast, so im guessing thats enough power to put your foot down in 3rd / 4th and lose traction (in dry) ?
Yeah frys 3rd and skips in 4th but if you change agresivlys 3rd to 4th you can get them going.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
