  • Replies 89
Posted Images
You know its a 25 yeah. Its making 8psi at 2000 and full boost at 3500. Said to be one of the most responsive cars race pace has tuned. Everything seems to be working really well together.
So it has a 25 bottom end with 26 head and plenum? It looks to be a 3071R or 3076R based on the comp cover?!?!?! Sounds very nice and responsive. Very keen to see it at the track. LOL. i would so give you my new suspension (Tein RAs) and brakes (Brembo f50 on 340mm rotors) so we can see an R32 GTSt with all the good gear mixing it with the GTRs :domokun: (if only i could afford to )
I do have my now spare Bilsteins that i was going to get re-valved and new platforms on to suit Eibach springs
I said it before and i'll say it again: Looks awesome!!!
Top work Adz.
Bris: it's a rb25 head and bottom, soon to be stroked to rb28. Only using plenum and throttle bodies.
Is the Garrett 3037 bigger or smaller than the Garrett GT30R (GT3076R, 500hp)?
So it has a 25 bottom end with 26 head and plenum? It looks to be a 3071R or 3076R based on the comp cover?!?!?! Sounds very nice and responsive. Very keen to see it at the track. LOL. i would so give you my new suspension (Tein RAs) and brakes (Brembo f50 on 340mm rotors) so we can see an R32 GTSt with all the good gear mixing it with the GTRs :thumbsup: (if only i could afford to )
So yeah as Al said its a RB25 head and bottom end with RB26 plenum and throttle bodies. It requires a Blitz adapter plate which is very hard to find in aus these days. I believe I have one of two in Aus supplied by Autobarn. You then need to re fabricate the thermostat housing to clear the VCT and relocate the idling gear as well as fit a RB26 oil filter adapter. Im sure there would be some other little tricks involved that only Race Pace know.
The turbo is a 3037 garret equivalent which is a 3076R. I really wanted to put big brembo's on but will see how the current set up goes and might have to wait for the bank to gain confidence in me again lol. Should give a few GTR's a run for their money.
Dont want to drift it atm as its too pretty and I dont want to muck it up in a hurry. Im sure drift will get the better of me sooner or later. Pretty sure it will be drifting by Christmas.
I wonder if the variable timing of the 25 head and PFc combined with the inlet plenum is the reason why the thing is so responsive. So what is th efinal mumber the car makes with the 3076R?
Does sound nice...please tell me it has open gate...the invasion of the loud GTSts :thumbsup:
Dude!!! Open gate all the way.
Yeah thats what I was going for. The setup is garenteed 40hp at the wheels straight up with heaps of response. In fact its all working a little to well. Due to the low back presure exhaust system and an efficent intake set up the exhaust gasses prefure to go throught the turbo than out the wate gate so shes over boosting. So final power figures and dyno sheets are not available. A new manifold and a 48mm wastegate are on their way to fix it all up. Then its time to finish the tune and shes done. Looking to make 300kw on good fuel day in day out on stock internals.
CHAMPION :thumbsup: Stock internals GTSt all the way BABY!!!!!!!!!!!! :O
I have an adaptor for the inlet drawn up and ready to do a mock fit up with for the RB25 inlet side using the RB26 inlet. Also the exhaust side as i dont think i can turn 100% homo and go low mount twins on the 26 head. I think i need to make up my adaptor plate so that i can run my RB20/25 HKS exhaust manifold with Brother Gate providing the tunes, all with the reliability of low mount cast manifold. All the plans depend on what i can source at a decent dollar figure...as beign atight ass R32 owner, i wont dare spend more more then 60% of what i spend per week on grog and Indan :D
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
