Hey guys,
Does any one have any idea if the front callipers from a R33 GTS25t or R34 Gt-t will bolt onto the V35?
Being a 2005 Coupe, I don't have the Brembo's, and I though if they can bolt on, the 4 piston callipers from the older Skylines might be a nice cheap upgrade for both performance and looks.
Any thoughts?
https://www.sau.com.au/forums/topic/175112-r3334-callipers-on-v35/
Mate if u want to wait till next week ill be pulling the calipers off my 33 race car this weekend to stick on the 35.. ill let u know how it goes.
I'm not in any kind of rush so that sounds great. Someone actually doing it is much better than taking a guess. :-)
Any idea on what such a swap would do to the break balance of the car. In my case if all is good and I go ahead, would moving from 2 pistons up front to 4 pistons, mean I would need to correct soemthing in the rear?
I personally dont think it would overally effect it, i drove my 33 round with non turbo rear brakes for ages on the street and its still that way now that its a full drag car with no worries, but dont quote me.
wisshing i hadnt sold the twin pot rears now though :(
Oh and cheers for the heads up on those rims mate ill check em out.
Edited by NA_R33
The Brembos come up for sale on a regular basis, especially from Z33 owners going to a big brake kit.
I got mine for $2500 with calipers, rotors and OEM pads...and that was over a year ago. Price should have dropped since then. I've seen quite a few people selling just the front calipers as well, so its also an idea.
Ok had it up on the hoist today, fitting the new coilovers.. The fronts are only SINGLE PISTONS!! i couldnt beleive it... But it doesnt look like 33 calipers will fit just by a quick look... there is a thread on here somewhere saying that it is possibl to fit 34 GTR calipers?? i think... either way im now looking at the G4 8 piston kit with 330mm rotors for 2300 from a mob in melbourne i think.. but it doesnt help for the rears..?? im really at loss as i cant seem to find many 350z brembos about... and im guessing to purchase them with some decent rotors ud be reaching the cost of teh 8 piston kit anyway...
Yahoo! Japan auctions should have them coming up.
And, like I said, $2500 for used Z33 Brembos. If you were to buy a new BBK from anyone else other than G8 (not a big fan of their products, their QC is shit, and my brakes are a component I don't want to be using unreliable parts on) $2500 wouldn't get you front calipers or rotors for the Z. The stock rotors, also being Brembo, are quite "reasonable" from a performance perspective.
I called around before I bought the Brembos, and most front kits were $4K from the reputable manufacturers (AP Racing, Brembo, etc). Going BBK all round was up around $8K.
  • 1 year later...
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
