Checked another Autobarn. They have it for $34.99 per 500ml bottle. Sounds pricey. Is that about right? Castrol dot 4 is only $10.
I get it from autobarn in Moorabbin and pay about that.
And if you think the $34odd (for 500ml) dollars is expensive try buying the castrol racing brake fluid....1 litre for about the $120 mark!!
Yeah price is right, good stuff though. Worst bit is I have an amost full bottle sitting in the garage. I had to open it as 1 wasn't enough when I was bleeding the brakes. Apparently its not good to leave it sitting round even though it's done up tight. Anyone know how true this is?
How longs it been sitting there?
I cant see how it sitting there would effect it, I mean it may sit on the shelves for months b4 sold.
Unless its once its been opened then its "shelf life" begins?
But yeah, 100% Autobarn should have it, if they dont ask them to call neighbouring stores for ya so u can swing past there n get.
I know the Scumshine store has plenty of them. :domokun:
Motorbike shops are the go :) I got it there last time and they always tend to have it. Where abouts are you?
Edit - Just re-read your post. Check the Motorbike shops down on Burwood Hwy in FTG near Safeway :)
Yep Try The motorbike shops there.. that's where i get mine from. The one with the Jetski shop downstairs... Don't think i was paying that much, think it was $25 or something, maybe 30...
Yeah I think the reason is the moisture in the air gets into it which is bad. But think about it - what about the fluid in your master cyl that is sitting there with a lid on it (probably not as air tight as the lid on the RBF600 bottle).... so yeah i don't belive it. I've got a half bottle sitting in my toolbox draw with the lid really tight...
Yep spot on ferni....as far as I know as you move up the dot rating (dot 4 - dot 5 - dot 5.1 etc) the brake fluid becomes more succeptable to absorbing water and as we know the higher the water content in the fluid the lower the boilng point etc which in turn means a dodgier brake pedal. This is why dot 4 brake fluid in most everyday cars don't need to be replaced as often as dot 5.1 fluid.
That said as long as you don't leave the container open for extended periods and the cap is on tight it should last a while.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
