Item: Nissan r32 skyline 4dr TURBO MANUALL!
Website: HERE!!
Item Condition: RB20DET manuall conversion was only done about 500kms ago..Mechanically A1 has hardly even driven since at all ince the conversion! Timing belt was replaced and new clutch put in at time of conversion. Paint has been done cheaply.. is bout 6/10.. there is a dent in passenger rear quater and drivers door.. there not that noticable. passenger window does not go down.. pretty sure its jus a brocken switch. missing 3 air vents.. no headunit and tuel gauge doesnt work. (light still comes on lol)
Reason for Selling: have another car on the way and have no room for this 1
Price and Payment Conditions: $6000!!! unregoed! NO TRADES, DONT ASK. (is currently regoed at the moment but prefer to sell unregod)
Extra Info:
* RB20DET Manuall, New timing belt, New HD Clutch, New battery, FMIC, 3" exhaust, Vented wide body Front Gaurds
* car has bout 116***kms, engine has 90***kms.
Pictures: couple that i took off my fone.. will post more better quality 1's wen my camera returns.
Contact Details: PM can call on 0402282959
This car is suited for sum1 who has time to spend on it... ive basically run out after doing the conversion... the engine runs as smooth as anything but jus needs time on the looks n fixing the little things.
I NEED THIS CAR GONE THIS WEEK!!!!! NO TYRE KICKER!!!!!!!!!!!!!!!!
Edited by heyhey!
https://www.sau.com.au/forums/topic/175145-4-door-r32/
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
