hey guys just installing my defi's and i was wondring if n e 1 knew where the factory boost line was or here i should tap in/?>?
thx
Its at the rear of the plenum and from there it goes to the map censor near the brake booster . The line near the plenum will be very hard and fragile because of the heat .
You don't have to tap in to it you can tap anywhere in the plenum you like , i fine the best place is the fuel reg.
when I installed my defi's I just turfed the factory map sensor, and put the defi in it's place. killed 2 birds with one stone. it gave me an easy place to mount the new sensor, and obiously the vacum line is already running there to the right spot. >_<
