Circuit Club 4th August Eastern Creek Trackday
padey
 Share
sorry im a n00b when it comes to these racing gigs.
its $245 does that include the licence? do i need a special licence? how long can i race for is like it a whole day thing or just 20min???
  • Replies 107
Don't be soft Raul.
I had a track day last weekend, I've got one on next Monday, Circuit Club that Saturday, and then Oran Park GP the weekend after that.
I'm hoping I still have pads, rotors and tyres at the end of it.
Don't be soft Raul.
Remember I'm driving pretty much a stocker so I try to limit it to 1 track day a month in the colder months only (not easy with so much temptation everywhere).
Plus I will be lucky if my current semis last the track day this weekend and I wont have time to get another set by next weekend.
Pitty because I was keen to attend this one.
What are the details for Oran Park? May be able to get my act together by then.
IM OUT :)
Cefiro just aint gonna be ready in time......
Oh well next time!
Liz make sure you get some practise in!! Still might pop out and watch for the day !!
next time mate.
What 1:18 in a 33GTR................ :(
I'll take my 1:13 in a taxi my good friend :sorcerer: :D
AHAHAH lol, but yes in seriousness, i want more grip and power!
Sign up mofo!
Bud ohhh bud it was the 32 my little weak friend and i would of gotten better times if i was runing spares then the tread I had on that day
I suggest you give Steveo's GTR excuse book back to him, he's going to be needing it soon
I'm in.
Lets try to get some garages together.
I'll speak to Narada. Nearly everyone gets a garage at EC anyway, so maybe we should all meet up somewhere and convoy in and take up a stack of garages.
ap
Fingers crossed I still be there.. visited my car yesterday.. I have been assured il be on the track Saturday.. but that damn Murphy fella keeps hanging around ;)
ap
Or whoever gets there first can just block a couple off.
Chubbs - still had slots as of this morning. EC is an awesome track.
I spoke to Narada and he is going to give us a group of garages in a row.
Can everyone confirm their attendance by checking i've put your name down in the 1st post in this thread. With some people changing there availability, i hope i haven't missed anyone.
I'll send Narada the list thursday night.
andrew
 Share
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
