hey guys, just bought my first turbo car which is a R32 gts-t and have some general knowledge about it but would like to know what are some good basic mods i can do to get the hp up. Not looking for huge amounts of power just yet but would like something around 250rwhp for now. Had it dyno'd a few weeks back at Hyperdrive in Malaga, good shop btw :thumbsup: and it made 190rwhp on 9-10psi which i have had turned up to run 13psi on high boost setting which is making 208rwhp.
The mods it has now are:
cat back exhaust, which im planning on finishing soon.
K&N air filter.
larger fuel pump and tank.
Frount mount intercooler.
Heavy duty button clutch.
Profec B boost controller.
Greddy Type R/S BOV.
So as you can see its pretty stock and would appreciate any feedback.
Oh, will try and get pics up ASAP
Edited by Zell
https://www.sau.com.au/forums/topic/175239-first-turbo/
well firstly welcome to the world of skylines and to the forum :O
basically the next thing you should be doing is finishing off the exhaust, should reduce restriction and hopefully gain some hp there,
im guessing after that you should be looking at a type piggyback ecu or depending on your budget a standalone system (good luck finding a power fc :thumbsup:)
one main thing to remember on these forums is to use the search function, which you will find to answer a few of your questions.
sam :D
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3211470
Nice mate, I just got my first turbo (RWD car for that matter) last week. While on the subject of mods does anyone know the price I should be paying for a decent fmi, I seen a hybrid kit they anygood for I think $900 diy? Because Im looking at getting the 400R front which is $995! wreckers anyone? Dump pipe hey ill have to look out for one of those.
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3211783
900$ for a hybrid sounds like you are gettin ripped
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212196
Yeah lots of people with RB20s seem to think the rb25 turbo makes a great difference.. wont cost too much either. Quite often people on here are selling them for $200 - $400ish. While you putting that on get the front/dump pipe done to finish your exhaust off :D
My cooler was $550(DIY) from autoworx.. its about 76mm wide and didn't need to cut the 400R front bar.
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212310
Alright cool. I just found the exact same fm for $450 brand new so I might get it from there. Cant beat Paul for service though and knowing his skylines! (almost bought a car from his but didnt). Where abouts did you grab your 400R front bar from, and what price roughly? If ya dont mind me asking.
Edited by Dani Boi
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212406
My car came with the 400R front, just fitted the matching 400R side skirts from mitchy's wreck.. rear bar OR maybe just pods are up next. I did see a full 400R kit on ebay, can't remember how much it was but I dunno if I would trust something from ebay to come to me without something being dodgy or it gets broken..
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212485
hey guys, thanks for the feedback. Now have a good idea of what is needed. The RB25 turbo i have also heard seems to run fairly well on the RB20, anyways finally got a chance to take some pics of the car for you guys to see :D. For some reason the pics seem to take for ever to upload onto this post so i have stored them in my gallery. Not sure if i need to add a link here somehow or if you guys can just look me up as a member and see the gallery that way
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3212944
if i were you i would go for something bigger than the rb25 turbo.
if you go to the effort to change the turbo, may as well put something decent on :(
and 250rwhp will be pushing the thing
Effort? it took 2hrs to do my swap and it was a direct swap, the only other thing that would be as easy to do is to buy the rb25 turbo and get it hiflowed before putting it on.
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3214484
direct swap? doesnt the oil feed banjo bolt on the 20 lines have a bigger hole? or did you use the 25 lines?
why are you asking about a front mount intercooler when the pictures already show one??? i'm confused
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3214752
Car belongs to Zell, and Dani Boi is the one askin about the cooler.
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3214780
I have heard this too but maybe I just got lucky, everything was a direct swap - I have a series 1 RB25 turbo with the steel compressor wheel so that could be why. Straight swap, easy as coz we did it at my mates workshop and he's pretty cluey with RB motors. The hardest part was wiggling the old turbo out and the new turbo in ;)
https://www.sau.com.au/forums/topic/175239-first-turbo/#findComment-3215925
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
