selling a 99model R34 GTR vpec
was complied in aus in 2002
has 75,000ks on the clock
rego till may 2008
APEXI programmable engine management computer
Front cam sprockets ? variable adjustment
Oil overflow bypass and oil restrictor fitted to head
electric Boost controller
Baffled sump
Oil cooler
Relocated oil filter
Main bearings changed when baffled sump fitted (precautionary)
3" Stainless steel HKS exhaust (cat back)
Competition head gasket and seals
Rear air diffuser
Transmission
Heavy duty single plate clutch
Gearbox synchros recently changed (precautionary)
Suspension/Brakes
Bilstein PSS 2 Coil over adjustable for height, rebound and compression
Dot 5 fluid and high performance road/race pads (brembos standard)
275/35 x 18 Michelin Pilot Sport tyres
Castor and camber adjusters
General
320Km/per hour Nismo speedometer
Just completed respray of skirts and spoilers
Quality pioneer removable radio and CD
Alarm including engine immobiliser
Quicktrak Satellite tracking anti theft system
Major service just completed
**serious buyers only**
if interested pm me
price : $63,500
Edited by XCLU5V
https://www.sau.com.au/forums/topic/175247-fs-r34-gtr-v-spec-sydney/
  • 1 month later...
  • 3 weeks later...
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
    • I must preface my comments with a general expression of ignorance. I have no specific knowledge of these NA automtaic things. I can only assume that the "steering wheel button" is for enabling the tiptronic controls. Wierd that it would even need/want a button for that... But anyway.... Was the car previously tiptronic? Did you put a new cluster in as part of all this?
    • Regardless, it doesn't seem wise especially on RBs to actually chase MBT. Timing scatter is the big one on stock CAS, even if that's fixed overshoot is worse than undershoot.
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
    • Ran into this bloke trying to give Oscar some advice pre-race today.
